Help Me Fix A Bad Latex Paint Job In My Bathroom Please - Painting - DIY Chatroom Home Improvement Forum
Old 09-15-2009, 11:34 AM   #1
help me fix a bad latex paint job in my bathroom please
how do I fix latex paint in my bathroom. I didn't prime after removing old wallpaper. There is much un-eveness with light and dark areas. Also the edges which were taped are peeling! Can someone tell me where to start? I think the current paint is still curing.
newpainter is offline   Reply With Quote
Old 09-15-2009, 06:50 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Post more information,please
What do you want to fix?
What have you done so far, etc, etc.
Old 09-15-2009, 09:58 PM   #3
Remodeler
MinConst's Avatar
We don't know when you painted this so the fact that the paint is still curing is confusing. If it is an hour fine if it is days you have a problem. If the paint dries and the wall is smooth then use a good primer over the paint and start over. Prep is key when painting anything. Taking shortcuts costs more time an $$ in the end. Lesson learned.
If the wall is not smooth and the paint does dry, you can scrape off the paint, and try to get it smooth. Have a skim coat of mud applied or have the walls textured. Prime and paint when the wall is prepared properly.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-16-2009, 12:34 PM   #4
Thanks for replying....I want to make the paint more even and repair the small spaces on the edges where I leftpainters tape on until after it dried (stupid me) My husband thinks he can fill in the unpainted edges with just more paint. I am afraid this s going to look horrible still.
Old 09-16-2009, 06:53 PM   #5
chrisn's Avatar
Rewards Points: 120
This will not work, you will need to spackle this area and sand smooth, the rest of it is hard to say with out more info or a pic but it sounds as if it all needs spackled( mudded) ,sanded and re painted.
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
painting Navagator Painting 6 10-13-2008 12:14 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
