Help Me With The Ceiling! PLEASE! - Painting - DIY Chatroom Home Improvement Forum
Old 10-10-2007, 04:23 AM   #1
Unhappy
Help me with the ceiling! PLEASE!
Hi there! I'm a DIY amateur and came for some help!
We have found deep cracks in the ceiling (which are a good 70 years old from what we can gather), so I mixed up some filler and away I went.
Anyway, my husband is mad because he says I have filled them too deeply and that it will show through the paint.
I was planning to do a good sand, then textured paint. What can I do to fix my over-enthusiastic filliing? What should I have done?
Is there any hope? Argh!!
Thanks in advance
themoneypit is offline   Reply With Quote
Old 10-10-2007, 08:20 AM   #2
apply a good coat of primer over all of ceiling, and you should be OK. This will give your finish coat a uniform substrate.
Tell hubby proper plaster crack repair is deep and beveled \-/ small opening at surface of ceiling. Don't rub his nose in this as you need him to help prime and paint.
good luck
Big Bob is offline   Reply With Quote
Old 10-10-2007, 09:03 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
You always should primer repairs before painting
Depending on the repairs, a full prime might be in order
slickshift is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
What type of ceiling should I use? dzimmer88 Remodeling 2 09-25-2007 04:18 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
