Help Matching Texture, What Mix To Use - Painting - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 10:26 AM   #1
Help Matching Texture, What Mix to Use
Having trouble matching this texture. I know it won't be perfect if blending, so I'm scraping the whole room down first. I would like it to match the rest of the home as close as I can. Any idea how to get this wider texture? I've tried both compounds with varying paint or water and my pattern is just too tight. See pics. Last one shows you what I'm coming up with.
Thanks!
Help Matching Texture, What Mix to Use-image-2025034070.jpg   Help Matching Texture, What Mix to Use-image-2288422774.jpg   Help Matching Texture, What Mix to Use-image-2930338270.jpg
RenoStruct is offline   Reply With Quote
Old 02-24-2012, 11:27 AM   #2
Too Short? Cut it Again!
Two look the same and the other looks like a fairly simple stipple pattern.
The "florette" pattern was most probably done with a special pattern stamp. You could try and make one to match out of carved rigid foam and then use drywall compound and some experimentation.
The last photo is easier. Your paint store should have a stipple roller cover that will leave a very similar texture.
Old 02-24-2012, 02:23 PM   #3
ltd
Rewards Points: 536
their are some good , well kind of good examples on youtube
ltd is offline   Reply With Quote
Old 02-24-2012, 02:29 PM   #4
Rewards Points: 13,446
http://www.all-wall.com/Categories/D...xture-Brushes/
That rosette pattern was most likly done with a special tool that pumps up and down as it's move down the ceiling.
Matching drywall ceiling texture roger35768 Drywall & Plaster 10 10-15-2012 08:23 AM
Need help matching existing texture mud99 Drywall & Plaster 8 06-22-2010 09:37 PM
Matching texture? Dbn107 Drywall & Plaster 3 03-24-2010 07:13 AM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 04:17 AM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
