Help With "leather" Faux Finish On Walls - Painting - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 10:26 AM   #1
Help with "leather" faux finish on walls
I followed the directions at http://www.hgtv.com/decorating/decor...her/index.html in order to create a leather look to my bedroom walls. The problem came during Step 4, when I was to apply "McCloskey Special Effects translucent color glaze (Mocha)" as my final top coat to give luster and depth to the walls. While I followed the instructions and used a foam roller, the result was disastrous. I could see every roll, every edge, and if I covered an area twice, the result was a deeper tone. It looked so awful that I let it dry and then went back to Steps 1 and 2.
I now have a nice look, but it is basically "flat" and I'd like to use some kind of clear glaze or varnish over the walls to give them a sheen. There is NO WAY I'm going to add colorant again; I just want something clear that will go on easily over what I have right now.
Can someone offer some suggestions?
luv2learn is offline   Reply With Quote
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
how to finish these walls off? FX4 Interior Decorating 13 12-07-2009 01:03 PM
Paint walls or install trim? raida357 Painting 14 11-12-2009 05:19 AM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 09:48 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
