Help With Lead Paint Test - Painting - DIY Chatroom Home Improvement Forum
Old 09-02-2015, 03:44 PM   #1
Rewards Points: 126
Help with Lead Paint Test
Howdy all!
I am about to paint a room in my '74 house so I got a Lead Paint test. It looked OK, but when it started to dry it turned a bit pink/red... Take a look at the attached photo. What say you? Lead or just the orange stuff drying?
Matthew
katanna is offline   Reply With Quote
Old 09-02-2015, 03:48 PM   #2
Rewards Points: 126
There was ZERO red on the corners where I cut into the wall, only that red tinge where the liquid ran down the wall and dried.
Matthew
Old 09-02-2015, 07:33 PM   #3
Rewards Points: 1,453
Just the orange stuff drying. Compare it to the test card. It is the exact same shade as the stuff OUTSIDE the circle. When there is lead, it is blood red like inside the circle.
mathmonger is offline   Reply With Quote
The Following User Says Thank You to mathmonger For This Useful Post:
Jmayspaint (09-02-2015)
Old 09-02-2015, 07:56 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
This has been my assumption that Orange only is essentially a negative result. If you want be more sure, send a sample into a lab. In any case, dust from old oil based paint (lead added or not) isn't too good for you. Might as well take precautions with dust anyway.
Jmayspaint is offline   Reply With Quote
Old 09-03-2015, 06:11 AM   #5
If you're just painting, it doesn't really matter if there is lead. By '74, I think lead was pretty much phasing out anyway.
Old 09-03-2015, 09:09 AM   #6
Rewards Points: 126
Copy. It wasn't the painting-over-it that I was worried about; I was going to sand the walls just a tad (as was recommended on the internets) and I was worried about the dust... then again, the top coat is most definitely NOT from before '78, so as long as I don't sand hard enough to get down a few layers then I should be fine.
Thanks all!
Matthew
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
painting advice rizzyboy Painting 10 03-25-2015 01:01 PM
Lead Paint Follow-Up RoughDraft Painting 24 06-18-2013 07:31 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Another Lead Paint Question loftezy Painting 6 02-28-2011 10:23 PM
