Help -- I May Have Bought The Wrong Paint, Need Advice - Painting - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 12:16 PM   #1
Rav
Rewards Points: 564
Exclamation
Help -- I may have bought the wrong paint, need advice
I'm in the process of refinishing a wood panel door. I cleaned, repaired, sanded, and primed with X-I-M UMA. Today I went to buy the paint. I had been planning on getting Duron Signature Select interior acrylic semi-gloss. However, they said they only sold it in gallons, and I only needed a quart. I let the guy talk me into getting SW Duration Home. After I got home I read some of the discussion on here about Duration, and a fair amount of it seemed negative (needs to go on thick, drys very fast, streaking, etc.).
I'd rather lose $17 on the Duration and spend too much getting more Signature Select than I need, rather than end up with an inferior job, or have a difficult time applying it. Not after all the work I've done (with the help of many on this site).
I'd appreciate your input. Thanks.
Rav is offline   Reply With Quote
Old 08-03-2012, 01:15 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Only speaking for myself and our employees, we have never had a problem with Duration interior or exterior paint. We actually just painted the interior of some metal doors yesterday with Duration interior semi-gloss with great results.
housepaintingny is offline   Reply With Quote
Old 08-03-2012, 02:20 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
If it were me I'd use a paint for trim, not walls. In the SW line that would be ProClassic Waterborne- semi gloss.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-03-2012, 04:31 PM   #4
Paint Pro
duaration exterior and duration home are excellent products. and the paint store STANDS BEHIND THEM! pretty much a satisfaction guarantee. .
Expert Paint is offline   Reply With Quote
Old 08-03-2012, 04:59 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
I'm with brush, but the Duration will be fine
Is it semi gloss?
Old 08-03-2012, 05:02 PM   #6
Rav
Rewards Points: 564
Is it semi gloss?
Yup -- semi-gloss.
Old 08-03-2012, 08:13 PM   #7
Too Short? Cut it Again!
It would not be my first pick but I wouldn't worry if you have it. I have never had problems with it. Might add some Floetrol and like others I would have picked a trim paint.
If you are really worried, donate it to a Habitat ReStore and add the amount to your tax deductions. Or see if the store will take it back as a mis-tint. I suspect they will if you have bought a lot from them.
Old 08-03-2012, 08:52 PM   #8
Rav
Rewards Points: 564
Thanks for the responses, all. My question at this point is, what makes a trim paint a trim paint? I mean, I assumed that being semi-gloss, this was a trim paint, but it sounds like some of you consider it to be more of a wall paint (which I had thought was what flat/satin was for). Why is SW Duration Home semi-gloss more a "wall" paint and something like Duron Signature Select interior acrylic semi-gloss more a "trim" paint? Thanks.
Old 08-04-2012, 05:50 AM   #9
chrisn's Avatar
Rewards Points: 396
Mr Rick?
Old 08-04-2012, 04:59 PM   #10
Rav
Rewards Points: 564
To make a long story short, after weighing the responses I got, I decided to be cautious and get and use the Duron Signature Select paint, which I got a good price on. I'm glad I did. It went on very smoothly and it looks very good. That's not to say the SW Duration wouldn't have worked but I didn't want to take a chance. At any rate, after a second coat I think I will be happy with how the door turns out. Thanks for everyone's help.
Tags
duration , interior , refinishing , select , signature
What did I do wrong? Behr paint horrible covering John Phoenix General DIY Discussions 35 11-17-2011 07:43 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
Need Advice on a Paint Sprayer HandyFrank Painting 15 01-09-2010 10:59 PM
I think I was stiffed by a Paint Contractor. Any advice? Shaun_in_NC Painting 4 09-28-2008 08:13 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
