Help With Epoxy Sealing Basement Floor - Painting - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 12:59 PM   #1
Help with epoxy sealing basement floor
I am in the middle of sealing my basement floor with Seal-Krete epoxy for garage and concrete. The basement concrete is very, VERY, smooth, so I thought I should etch it. Well I got some advice from somebody saying not to etch it and just use a primer. So now that I have a section done, I am finding it to be scratching and chipping very easily. My question is, should I get another kind of sealer (clear) to apply over the epoxy coat?
Zefrik is offline   Reply With Quote
Old 08-28-2012, 01:02 PM   #2
Should I use something like this.....
http://sealkrete.com/clearseal.html
Old 08-28-2012, 01:55 PM   #3
Too Short? Cut it Again!
Sounds like you are getting lots of advice and none of it good or coherent. What did the epoxy product you used say to do?
Except in some special situations and calling for specialized products, primers are usually not used on floors under regular floor finishes. They are just not built for floors. Things like floor paints are self priming.
If your project is scratching or chipping all the way to the concrete than that primer you put down is not adhering to the concrete because it was the wrong material or you raced application of the finish coat. If the epoxy is chipping or flaking off than you have legitimate issues with the product so long as you applied it correctly.
You should not have to put anything over the recommended number of epoxy coats. And you cannot fix base level adhesion by adding more top coats.
The Following User Says Thank You to user1007 For This Useful Post:
ltd (08-28-2012)
Old 08-28-2012, 04:17 PM   #4
Oh .
I am just going to have to leave it for now. I have already had to scrape paint off manually. WHY did that person talk me out of etching?!?!?!?
The primer I had said it was for all surfaces including concrete and masonry.
I applied the first very lightly. I even followed the directions on the back of the can and added a bit of water to the first batch to thin it up a bit. I really do not know why this is so complicated.
Old 08-28-2012, 05:41 PM   #5
But that probably did not mean those materials when floors. It should be adhering though.
Old 08-28-2012, 05:45 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
no primer on floors, unless you are never going to walk on them
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Basement Floor drainage help wizardofgore Building & Construction 3 07-11-2011 11:42 AM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 06:24 PM
Sealing Garage Floor Painted with 2 part Epoxy GregfromOHio Painting 3 08-26-2008 01:41 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
