Help With Drywall Prep - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 11:09 AM   #1
Help with drywall prep
When I removed wall paper from bathroom some of the drywall paper came off as well.What is the best way to prep walls for painting. Have gotten so many different suggestions>
Do I really need to cover the whole surface with mud?
Or do I need to prime it first? PLEASE ADVISE. I'd like to start as soon as possible.
Thanks for the Help.
Rosie not the R is offline   Reply With Quote
Old 03-01-2012, 11:34 AM   #2
Mr. Paint's Avatar
Rosie: You may get alot of people here advising you that drywall repair is not a good DIY project; it is best left to an expierienced professional. That is my advice. That being said, If you are going to proceed, buy Zinsser Gardz primer and all-purpose joint compound, a 12" mud pan, a 6" and 12" joint knife, a hand or pole sander and some pre-cut sanding meshes.
First, be sure you have washed off the drywall paste and completely prime the wall, damaged areas and all. You will next need to patch all the damaged areas with joint compound and sand smooth when dried. Floating out an entire wall is great, but, it's not a good idea for the inexperienced. Prime all the patches with Gardz and proceed to finish.
Sound easy? It always sounds easy...
Good luck with your project.
Mr. Paint is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr. Paint For This Useful Post:
Brushjockey (03-01-2012), Rosie not the R (03-01-2012)
Old 03-01-2012, 11:42 AM   #3
Mr. Paint,
Thanks for the info. And since I'm a little above broke, I'll try my best and hope it looks half decent. Wish me luck.
Old 03-01-2012, 04:28 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 304
Originally Posted by Rosie not the R View Post
Mr. Paint,
Aren't we all.
chrisn is online now   Reply With Quote
Old 03-01-2012, 07:29 PM   #5
Gymschu's Avatar
Rewards Points: 652
Originally Posted by chrisn View Post
Aren't we all.
Chris, I guess I have been misinformed. Here I thought you were raking in bags of money on the "Difference between glue and adhesive" lecture circuit.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
jsheridan (03-01-2012), ltd (03-01-2012)
Old 03-02-2012, 03:57 AM   #6
chrisn's Avatar
Rewards Points: 304
It does not pay that well, it is mostly a public service
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (03-02-2012)
Old 03-02-2012, 04:20 AM   #7
A real humanitarian.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 03-02-2012, 04:23 PM   #8
chrisn's Avatar
Rewards Points: 304
I do my best
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
