Help With Aerosol Spray Paint! - Painting - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 10:38 PM   #1
Help with aerosol spray paint!
Guys, having trouble getting a smooth finish using flat/matte black on metal! Anyone have any tips? It has a rougher surface than I'm looking for. I'm not using a textured paint, its just flat black. Could it be the brand? To much or little paint? My prepwork is good, it's either my painting technique or the paint. Thanks for any tips!!!
aztsm is offline   Reply With Quote
Old 03-04-2012, 10:41 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
How is it coming out? Pictures?
ddawg16 is online now   Reply With Quote
Old 03-04-2012, 10:43 PM   #3
Rewards Points: 13,960
And you primed it first right?
Many thin coats is far better then a few thick ones.
Flat black is tough to get to come out even.
Do not just stand there and point in one spot and spray. Short burst and keep it moving from side to side.
Old 03-05-2012, 05:49 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Run a bucket of hot tap water and submerge your cans in it for a few minutes. Heating the cans can help them spray smoother. Be safe about it though. Too much heat and they'll explode. Hot water should be safe.
Darkling Designs
poppameth is offline   Reply With Quote
Old 03-05-2012, 07:45 AM   #5
Learning Things Every Day
Jay 78's Avatar
^ This.
It sounds to me like you're applying the coats too heavy. When a coat of spray paint is applied too thick, it can lead to over spray resting on top of the surface, causing a rough, uneven looking finish.
Under Construction
Jay 78 is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Spray Painting without aerosol cans christina4346 Painting 4 10-05-2011 03:11 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
