Help!!! - Painting - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 03:58 PM   #1
Help!!!
I mistakenly primed over wallpaper glue and now the wall looks like a mess. Is there anyway to fix it?? Ive read about a Zinsser Guardz that is supposed to work well.....any advice would be great!!
shannamr is offline   Reply With Quote
Old 02-27-2013, 04:05 PM   #2
cdaniels's Avatar
Now that it's sealed with primer probably going to have to sand and skim and sand some more.It would have been a lot easier to remove the PASTE but now It's too late most likely.You could try to get the PASTE wet and moving again so you could scrape it off but probably not going to be able to once it's sealed with a primer.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-27-2013, 04:06 PM   #3
what do you mean by "skim"?
Old 02-27-2013, 04:10 PM   #4
cdaniels's Avatar
Smoothing out what you can't sand smooth by "skimming" with joint compound.You can search you tube for videos that will show you better than I can explain it most likely.
Old 02-27-2013, 04:49 PM   #5
Gymschu's Avatar
Rewards Points: 236
Shanamr, there are literally dozens of threads on this very topic on here. Do a search and lots of reading and you will get good advice and guidance.
Hey let's paint over wallpaper glue
