Old 08-05-2010, 10:37 PM   #1
haze on timber
We have been renovating a 1920s rail carriages and have cleaning all of the timber and pressed metal and either recoated with oil based paint or oiled the surface with a product called penitrol oil. This was done in the warmer months, since then the surfaces have developed a haze/fog on the surface. It can be wiped off but reappears a few days later, we are at a loss to know what the problem is. We don't think it is blooming and we have insulated the carriage thoroughly to prevent changed in temperature. Any suggestions?
davidj is offline   Reply With Quote
Old 08-06-2010, 06:48 AM   #2
haze on timber
Floods penetrol is a paint conditioner, used for making oil based paint flow better. What should have been used is a wood penetrating oil, but that is hind sight now. Since I have never been in your shoes, I would be guessing about what you should do as to a fix. So here is my guess, get some wood penetrating oil and coat to cover what you have done.......... Hope it works out for you.
mark942 is offline   Reply With Quote
Removing haze from ceramic tile tripower Flooring 10 02-20-2012 09:53 PM
Removing haze left by paint stripper & TSP Handy Vinny Painting 5 07-22-2010 01:05 PM
Cannot remove haze from tile grout Woody36 Flooring 1 10-12-2009 09:54 PM
Timber retaining wall repair *Kennedy* Landscaping & Lawn Care 2 03-26-2009 07:02 PM
Hybrid Timber Frame 4powells Building & Construction 2 05-03-2005 10:14 AM
