Have I Made A Huge Mistake (latex Over Oil)? - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 02:29 PM   #1
Rewards Points: 91
have i made a huge mistake (latex over oil)?
Guys,
So after carefully planning out my post wallpaper wall prep (on another thread) I think I might have made a huge mistake with my non-wallpaper rooms.
I went through, and painted 3 good sized rooms with a high quality acrylic latex paint (Dunn Edwards, Spartawall to be exact). As the rooms had paint on the wall already, and were in reasonable shape, i figured no need to prime - I repaired a few cracks, cleaned the walls, and put on two coats of paint, finishing yesterday. Now it's only now occuring to me that these walls were probably oil/lead paint. Most of the house has been a time-capsule since 1959 - original everything, even basic things had not been updated. The walls certainly didn't look like they'd been painted in a good long time, if ever, and were very dirty - I washed them down prior to painting.
So...if they were oil/lead, how much trouble am I in? Have i just wasted the time, money, and paint? Am i going to need to reinvest a lot more time and money trying to remove the latex paint and properly prep the wall? Any chance this just 'works out'? (said in a fairly desperate tone..)
appreciate all advice,
thanks,
Matt
mmhendrie is offline   Reply With Quote
Old 04-29-2013, 04:45 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
What was the sheen of the old paint? Usually with walls , if they were flat or near flat, that will give enough for the new paint to grab on to.
If they were a shiny paint, might be a bit of a problem.
But walls are more forgiving ( usually) than trim that gets bumped alot.
Give it a month ( to cure totally) and then there is a slightly invasive test you can do. (inconspicuous spot)
Make an x with a razor knife just deep enough to go through the new paint.
Put a piece of tape on it, and then put it off. Did the new paint come off easily also?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-30-2013, 01:10 PM   #3
Rewards Points: 91
thanks for the advice - i'll give that a try!
The walls i painted were all flat, and I used flat paint on top on all of them except one room - my childs, where i used 'velvet' - which is above flat but below eggshell on the shiny scale.
I'll keep my fingers crossed and be more careful in future!!!
Old 04-30-2013, 05:45 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
You are probably fine, it was pretty rare for oil to be used on walls. It was done, but not much.
Old 04-30-2013, 08:51 PM   #5
This was a hot product!
Old 05-01-2013, 04:01 AM   #6
chrisn's Avatar
Rewards Points: 236
Maybe out there, I never heard of it
Like I said ,it was done, just not that much
Old 05-01-2013, 08:08 AM   #7
LOL- Chris, you are so easy. Look at that ad- when do you think that it was made? Never heard of it..
but it may have been around when the op's walls were originally done.
Old 05-01-2013, 06:17 PM   #8
chrisn's Avatar
Rewards Points: 236
EASY? me? I saw the ad, still never heard of it
certainly it COULD be on the wall, my point was, probably not
Solution for Bad Advice - Latex on Bookcase greenthumb General DIY Discussions 8 08-16-2010 06:58 PM
Durability - Oil or Latex polarzak Painting 4 01-14-2010 06:16 PM
Paint sticking at door/jamb Corcoran1 Painting 10 06-20-2008 08:03 AM
made mistake cutting an interior door phild01 Carpentry 9 04-09-2008 05:07 PM
Help! Our contractor made our kitchen cabinet door stain TOO ORANGE! Nikki99 Painting 12 11-20-2007 12:45 AM
