Has Anyone Painted By Hand Over Lacquered Cabinets With Oil? - Painting - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 07:59 PM   #1
KLR
Question
Has Anyone Painted by Hand Over Lacquered Cabinets With Oil?
Hi, Has anyone personally painted by hand (brush or roller) over lacquered cabinets with an oil based paint???
Our white lacquered cabinets are too yellow. Want to go with something I can do my self (without spraying). The top coat that is on the cabinets now is Valspar Luster Lac Premium "Water White" Lacquer 680 VOC - 20 Sheen.
The finish is not peeling or anything just yellowed badly. There a few hairline cracks I need to fill at the joints also.
Read alot of maybe, this maybe that advice. This is a big job and I want to be sure it will work. Anyone with experience in doing this, Please help?
What brand of wood filler (is elmers okay or do I need an oil based filler?)
What type of primer did you use?
Oil Based Paint, but what particular kind?
Thanks in advance for your help, Kay
KLR is offline   Reply With Quote
Old 06-18-2009, 10:43 PM   #2
Whatamess
I have done it and looked fine. You must sand first (I use an orbital sander with 220 grit and a vacuum hooked to it) then use filler for cracks. You will never totally hide the brush marks but no one but you and maybe a pro will know the difference. Good luck.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 06-19-2009, 05:45 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
If you paint them with oil, they will again turn yellow.
Sand, clean, prime ( BM Fresh Start), paint with a GOOD, latex semi gloss. ( BM Satin Impervo waterbourne would be my choice
Old 06-21-2009, 06:40 PM   #4
KLR
Latex just has such a bad wrap from everything I read, did not want to go that route. Yellowing being the problem with oil too, I may have to. Have seen some good things about Impervo. Thanks so much for your replies, Kay
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 11:23 AM
Choosing a painter.... Kitchen Cabinets Painted STARL Painting 7 09-23-2007 01:53 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Refacing Painted Cabinets tripdls Carpentry 4 11-04-2006 12:34 PM
