Hardiplank And Paint Quality - Painting - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 04:10 PM   #1
Hardiplank and Paint Quality
How often do I need to paint hardiplank in North Carolina and does paint quality make a difference (eg SW Duration v. Superpaint)?
curtinbond is offline   Reply With Quote
Old 07-04-2011, 04:21 PM   #2
Rewards Points: 5,336
Paint quality always makes a difference.
You paint it as often as needed.
The cheaper the paint the more frequently you paint it.
As a corrollary, the less you prep for painting, the more frequently you paint.
Ron
B. Franklin 1759
Old 07-04-2011, 05:20 PM   #3
Thanks for the quick response. We purchased a home that was was new construction painted hardiplank in 2004 but paint colors were mismatched on the front and I think the paint used was SW Superpaint. I thought 8-10 years was a reasonable repaint schedule for hardiplank and am wondering if I should just try and repaint the front where the mismatch is or whether at 7 years I should go ahead and repaint (the trim is wood which needs to be painted anyway). I am also wondering if Duration paint (and color) will hold up better in the sun here?
Old 07-04-2011, 06:35 PM   #4
I'd look at Consumer's Reports for the latest paint gradings. As I recall Behr did very well. No idea about Sherwin Williams.
Can't say whether to paint just the side or the whole house as I have no idea of the shape.
Ron
B. Franklin 1759
Old 07-04-2011, 08:17 PM   #5
Gymschu's Avatar
Rewards Points: 490
Hardiplank paint jobs last a good 8-10 years. Some Hardieplank suffered from poor primer applied at the factory and the finish paints applied to that showed areas of discoloration. On new Hardie I now apply SW's Loxon primer before painting. This assures a more even finish and protects you from the possibility of poor factory primer issues. I would use SW's SuperPaint before I would use any BEHR paint. Behr is junk, IMO.
Old 07-05-2011, 07:05 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Originally Posted by Ron6519;679809[COLOR=red
]I'd look at Consumer's Reports for the latest paint gradings.[/COLOR] As I recall Behr did very well. No idea about Sherwin Williams.
Good to use for toilet paper but even that's not so good, to rough
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (07-05-2011)
Hardiplank siding painting Saorsa Painting 1 06-27-2011 09:11 PM
filling and painting seams in Hardiplank denemante Painting 2 05-16-2011 04:03 PM
Hardiplank Siding repainting/staining cpharris Painting 1 10-21-2010 02:57 PM
Hardiplank Painting hardipaint Painting 5 10-24-2008 05:54 PM
Exterior Paint recommendations staylor34 Painting 6 10-08-2008 05:36 PM
