Hardie Plank Paint Bubbling - Painting - DIY Chatroom Home Improvement Forum
Old 04-25-2009, 02:55 PM   #1
Last year we had a contractor install Hardie Plank and paint it with the recommened paint. This spring I see where snow was up against the side of the house the paint is bubbling. Is this an issue with improper painting or is this a problem that Hardie Plank has?
mkleecowalleymi is offline   Reply With Quote
Old 04-25-2009, 03:39 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
hardi can and will absorb moisture at the edge
Tom Struble is offline   Reply With Quote
Old 04-25-2009, 04:02 PM   #3
Hardi needs to be kept from soaking up moisture. You need to keep the snow from piling up against the building. Sounds like you have vapor drive pushing the paint off.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 04-25-2009, 06:29 PM   #4
check the lower edge of the siding is it starting to delaminate?If they are i would replace any bad ones and repaint them paying attention to get the lower edge sealed with a high quality paint.Hardie should be started no closer than8'' above finished grade
Old 04-25-2009, 06:32 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
All true
The Hardi isn't failing, the coating is
Could be the coating prep, coating application, or it could be the improper
installation of the Hardi (based on your region...check your local regs.)
slickshift is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Paint blistering and/or bubbling issues stro77 Painting 8 10-05-2012 11:59 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
