Hard Freeze... - Painting - DIY Chatroom Home Improvement Forum
Old 03-14-2014, 10:19 PM   #1
Rewards Points: 155
Hard Freeze...
I stored some gallons of paint in my shop (some full, some at varying levels). I'm in the deep south, so the winters are typically mild. This year was an untypically cold winter in which a night or two was a "hard freeze", which means that it stayed below freezing all night. My shop walls are 1/2 in. grooved panels with no insulation, so I'm sure the temps stayed below freezing for several hours. The paint is latex (some flat, some eggshell). So, the question: Usable or trash?
Bob... is offline   Reply With Quote
Old 03-15-2014, 02:51 AM   #2
(the original)
Rewards Points: 756
Unless it was already old, it should be fine. I've been down here since '05 and this is definitely the longest, coldest winter so far, but didn't affect any of the products stored in my uninsulated shop. I think it takes a good deal longer for paints to freeze than it does water...
Open the cans, give them a stir...if it looks good, use it. What they call a hard freeze down here is something like 6-8 hours below 32F....where I came from, that's T-shirt weather
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
Bob... (03-15-2014)
Old 03-15-2014, 07:27 AM   #3
Rewards Points: 5,994
Use it. I really doubt they froze solid.
ToolSeeker is online now   Reply With Quote
The Following User Says Thank You to ToolSeeker For This Useful Post:
Bob... (03-15-2014)
Old 03-15-2014, 07:33 AM   #4
Painting Contractor
rbriggs82's Avatar
Rewards Points: 77
They will be fine, it takes pretty cold temps to freeze paint solid.
Plus paint can go through several freeze thaw cycles before going bad. Open it up and give it a stir. You'll know it's not good of it has a gritty consistency.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
-Ryan
ParagonPainting.com
Facebook |Google+ |Twitter
rbriggs82 is offline   Reply With Quote
The Following 4 Users Say Thank You to rbriggs82 For This Useful Post:
Bob... (03-15-2014), Danahy (03-15-2014), oh'mike (03-15-2014), ToolSeeker (03-15-2014)
Old 03-15-2014, 10:19 AM   #5
Rewards Points: 155
Great! Thank you for your replies. The thought of throwing out several hundred dollars of paint wasn't helping my day.
Old 03-17-2014, 09:22 AM   #6
Rewards Points: 394
As latex paints are about 50% water, and there is less protection against freezing in the product formulations, these products can be affected by a partial freeze. Paints with low VOC's do not have the feeze/thaw cycle tolerance that they had in the past.
Let the product warm up to room temperature, stir or shake, and evaluate. In most cases, the product is usable, but product with an adverse odor or excessive debris is not. Good luck.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
Bob... (03-17-2014)
Fire Sprinkler Freeze Fix golddog Plumbing 20 09-27-2011 07:08 PM
Hard Duct. Garalee HVAC 4 03-08-2011 03:41 PM
Masonite front door hard to open and close moopey Carpentry 5 10-04-2010 10:41 PM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 05:30 AM
Diference between Fiberglass and Hard Foam shumakerscott Roofing/Siding 3 09-06-2008 12:16 PM
