Hanging A Wallpaper Border - Painting - DIY Chatroom Home Improvement Forum
Old 12-12-2003, 10:43 AM   #1
Hanging a Wallpaper Border
Tim Bodine has written an excellent DIY - How To Guide that can be found here: Hanging a Wallpaper Border
If you have any questions about this guide please post it here in this thread.
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline   Reply With Quote
Old 02-24-2004, 10:10 AM   #2
Guest
Guest
Posts: n/a
taking down a wallpaper border
hi i was wondering if you could give me some tips about taking down a wallpaper border.
Old 02-27-2004, 04:53 PM   #3
Mark's Avatar
Taking it down is the fun part. Peel off the top layer exposing the paper backing thats stuck to the wall. Using some wallpaper remover in a small spray bottle wet the paper liner a couple times to trigger the release of the glue. Using a 3" sharp scraper gently remove the we liner making sure to keep wetting ahead of your work direction. After its all off scrub the walls with a mixture of TSP powder and hot water (use rubber gloves) to remove any residue or gobs of the old paste.
Mark is offline   Reply With Quote
Old 03-03-2004, 03:28 PM   #4
If you are going to paint over it even if you have washed it you may need to prime the area with an oil-based primer to prevent reactivation of the boarder glue by a water-based paint.
Stelablu is offline   Reply With Quote
Old 03-04-2004, 08:17 AM   #5
Paperhanger/painter
ProWallGuy's Avatar
That is true Stelablu. If the paste comes off fairly easy, I use Zinsser's Gardz or DrawTite by Scotch Paints too. They both work great, dry fast, and apply much easier than oil products.
ProWallGuy
Professional Wallpaper & Paint Co.
ProWallGuy is offline   Reply With Quote
Old 03-24-2005, 10:28 PM   #6
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
Thumbs up
I'll second the vote for Gardz, great stuff!! I highly recommend it!!
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 03-24-2005, 10:50 PM   #7
Contractor
My paperhangers insist on Zinsser B-I-N. I don't ask, just do.
Teetorbilt is offline   Reply With Quote
Old 03-25-2005, 01:13 AM   #8
aka:awesomedell
Rewards Points: 150
Sounds like the help has the boss well trained Teeterbilt. :D And what makes you the guy the quality help wants to work for, there be method to your madness.
Old 03-25-2005, 07:45 AM   #9
Contractor
Housedocs, I use 4 paperhangers with a combined experience of 115 yrs and one of them is 3rd generation. How could I possibly argue?
Old 03-25-2005, 11:56 AM   #10
aka:awesomedell
Rewards Points: 150
:D How could you indeed!
Old 06-17-2005, 01:19 PM   #11
Removing wallpaper is a PITA. I just moved into a place with 14 yr old paper on one wall (about 8ftx12ft). Even with chems, it took me 6 hours to get it all off. NEVER again...
meiersenterprises is offline   Reply With Quote
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 11:21 AM
wallpaper?? lauriemariee Painting 6 11-23-2006 07:40 AM
wallpaper border over faux paint hevnbnd Painting 2 10-09-2006 04:17 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 12:13 AM
