'halo' Effect Around Paint Touchups? - Painting - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 11:28 AM   #1
DIYguy2000's Avatar
Rewards Points: 93
'halo' effect around paint touchups?
We bought a new house a few months back and re-painted all the walls. After our move-in, and a few nicks, dents and scuff marks later, it was time to do the touchups.
I filled in nicks and dents with drywall compound and sanded.
I mixed the paint very well and did two coats of touchups with a brush. Now, the areas 'surrounding' where I did the touchups (where little paint was applied to the wall from my brush) have a 'halo' effect, or show a different texture when the light is shining off it.
Touchups over scuff marks show the same thing (not just over drywall mud).
Is this because I used a brush instead of a roller? I washed down the walls before and after and its still noticeable in certain light.
Should I just roll overtop of this? Will I have to re-do the whole wall if I do?
Thanks!
DIYguy2000 is offline   Reply With Quote
Old 02-02-2010, 12:45 PM   #2
Sprayboy-services.com
Did you ever notice that when a wrecked car is fixed they repaint the whole door, whole quarter panel, to get a better match? This is similar. Even a high quality paint like Aura fades with time. A roller won't help either. You may need to repaint a whole wall at a time as the new paint will have more lustre than the old. The higher the gloss the more you will notice the difference. JMHO
Sprayboy is offline   Reply With Quote
Old 02-02-2010, 02:01 PM   #3
Too Short? Cut it Again!
Poor quality box store paint could be a factor here but my guess?
Remember that latex/acrylic paint takes 30 days to cure to its surface sheen. How long has it been since you did the touch-up? This may resolve itself if it has not been a month. Obviously differences will be less noticeable in the meantime with flat than as you move up in gloss to satin, eggshell, semi, high gloss, etc.
Old 02-02-2010, 02:06 PM   #4
DIYguy2000's Avatar
Rewards Points: 93
original latex painting was done 5 months ago. Touch-ups were 2 days ago. I'll keep an eye on it.... I guess this puts a whole new meaning to "watching paint dry"
Old 02-02-2010, 04:15 PM   #5
Rewards Points: 346
If you used a roller to paint the wall a brush will not make an a good repair. Use a small roller and roll the paint out in all directions for the nick.
Rege
RegeSullivan is offline   Reply With Quote
Old 02-02-2010, 05:34 PM   #6
WindowTreatment Installer
A roller is going to have a more textured look more so than a brush. I would use the roller over it. Another factor is the quality of the paint. A good quality will blend well with touch ups. I use only one brand in my house and one reason is it touches up well . I'vd done touch ups several years later and can't tell where it was.
bobtheblindguy is offline   Reply With Quote
Old 02-02-2010, 10:56 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Very common when touching up paint. This is "Flashing" A roller is less likely to do it. Flat paint is least likely to flash and eggshell is just about the worst.
Old 02-04-2010, 06:21 AM   #8
DIYguy2000's Avatar
Rewards Points: 93
I'll give a roller a try this weekend. and yes.. it is eggshell. The center of my touch-ups look fine, its just the outer edges. Hopefully a quick roll will solve my problems without having to do the whole wall. Thanks for all your help!
Old 02-04-2010, 06:27 AM   #9
I say again, patience. You are not going to know what you really have for 30 days.
Old 02-04-2010, 06:38 AM   #10
DIYguy2000's Avatar
Rewards Points: 93
True... maybe I'll get something else done off of my to-do list for now and keep an eye on it.
Old 02-04-2010, 08:54 AM   #11
Rewards Points: 346
While I agree it may look a little different in 30 days, I would give the roller a shot asap. It will save you another 30 days and only take a few minutes + clean up time. Also the longer you wait the less likely it will match. I'm not saying a few days would make a difference but a few months will. You will rarely if ever get an acceptable repair with a brush if the paint was originally rolled. And, you will rarely if ever get an acceptable repair with a roller if the paint was originally brushed. If it really is a tough match will be most successful if you go from floor to ceiling and work out 10 -12 inches to both sides of the repair allowing the roller to dry out as you go.
Good luck and let us know how it works out for you.
Rege
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
