Hairline Cracks In Paint Of Handmade Shelves - Painting - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 11:34 AM   #1
Question
Hairline cracks in paint of handmade shelves
Hi!
So the previous owners handmade floating shelves for the wall in the dining room. I recently finished remodeling the room and I am trying to fix up the shelves. There are hairline cracks in the paint that I am not sure how to repair. They must have put on 7,234 layers of paint because I could sand all day long and still not smooth out the cracks!!
Should I fill the cracks in with a wood putty? What is the best way to repair them?
Thank you
handsforasl is offline   Reply With Quote
Old 04-22-2013, 02:43 PM   #2
Rewards Points: 6,034
My first thought is random orbit sander. If there is that much paint on there you may run the risk of the same thing happening again. And if they are not smoothed out almost perfect they will show thru your new paint.
Old 04-22-2013, 03:25 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
That is caused by different levels of paint expanding/contracting at different rates.
I would sand for adhesion ( scuff sand), clean off and put a thick coat of peel stop on them.
Or another approach would be prime with Zin 123 and skim with Elmers wood filler, sand smooth, reprime and finish.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-22-2013, 03:40 PM   #4
Brush if you do that aren't you still going to have the same problem with the expanding and contraction?
Old 04-22-2013, 03:55 PM   #5
Peel bond has flex, and the wood filler also has some flex, as does the acrylic primer. Most waterborne enamels also have some give.
Probably someone painted it with a flat and then went over it with an oil enamel, which has no flex but gets brittle over time.
That is one advantage of the new gen of paints.
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (04-22-2013)
Old 04-22-2013, 05:00 PM   #6
Thank you very much for the suggestion. Sounds like a good plan.
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Hairline cracks in shower tile. nodsirrah Kitchen & Bath Remodeling 6 05-26-2011 08:16 PM
repairing large cracks in paint joefromcal Painting 3 05-21-2009 09:08 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
