Groove Prep For Painting; Vertical Siding - Painting - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 03:26 PM   #1
Groove prep for painting; vertical siding
My house is sided with 4x8 sheets of grooved painted vertical siding. The paint in the grooves is cracked. I need a relatively efficient way to remove the paint from the grooves in preparation for repainting. Any suggestions?
BearsPaw is offline   Reply With Quote
Old 05-08-2011, 04:18 PM   #2
Gymschu's Avatar
Rewards Points: 930
Gentle pressure washing will remove a lot of it.......then you can buy various scrapers in different shapes to get into the groves and remove what's left. You might even be able to use the side of a sponge sander to get into the groove and remove paint.
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 07:58 AM
Should tongue and groove siding be caulked? apara Building & Construction 5 08-15-2010 06:07 PM
How to repair vertical wood siding? darsunt Building & Construction 1 11-19-2009 06:46 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
