Graying Cedar - Painting - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 08:36 PM   #1
Rewards Points: 182
Graying Cedar
Will a semi-transparent stain look like the sample when applied to graying or gray cedar? Should any special treatment be applied to the graying/gray cedar before applying the semi-transparent stain to boost the stains color?
sore thumb is offline   Reply With Quote
Old 06-18-2013, 08:49 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
Oxalic acid based wood brighteners work especially well on graying cedar. It can really make it look new. Helps if you can do a strong hose rinse or light pressure wash after applying.
The Benjamin Moore brand brightener is my favorite, But There are lots of different brands of brightener that work well.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
sore thumb (06-18-2013)
Old 06-18-2013, 09:27 PM   #3
Gymschu's Avatar
Rewards Points: 208
No. The gray represents dirt, algae, mildew, mold, etc. that has grown on the surface over the years. Some like that gray look. If you put stain over all that dirt, etc. it's going to be one ugly mess. If you are seeking the cedar color, you MUST clean as Jmayspaint suggested, allow the cedar to dry, then apply your stain.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
Old 06-18-2013, 09:47 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Clean first using a sodium percarbonate based wood cleaner, nylon scrub brush and low pressure. After cleaning you can then apply oxalic acid, citric acid or a blend of both to brighten.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Old 06-19-2013, 08:05 AM   #5
Too Short? Cut it Again!
Yup. You do not want to use either a basic or acid reaction to clean the cedar without neutralizing its reaction with the other. Water on its own may not be enough to fully stop the chemical reaction on its own.
A real paint store will have a conditioning system that will work nicely.
Even with the cedar cleaned and brightened you should test the semi-transparent stain to make sure it is going to give you the color you want.
The Following User Says Thank You to user1007 For This Useful Post:
sore thumb (06-19-2013)
Should I replace my vertical cedar siding? mpnret Roofing/Siding 20 09-13-2014 09:55 AM
Clear Heart Cedar turns black DMAGNER Painting 3 08-21-2012 01:45 PM
cedar shakes by crane or cedar impressions elva Building & Construction 16 06-20-2010 08:51 PM
cedar deck looks like crap silky Painting 16 05-02-2009 11:42 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
