Old 09-29-2012, 01:02 AM   #1
Gray stain question for kiln dried deck
I'm building a new deck in the NW and the plan is to use kiln dried cedar deck boards. Since cedar eventually goes gray, I am not going to fight it this time. I'm using Sikkens Cetol SRD semi-transparent stain in cape cod gray. I have the option of pre dipping the boards. My fear is the stain will keep the boards from turning gray. Would it be a better option to stain the deck after it ages a bit. Anyone have experience with achieving this kind of look?
steuspeed is offline   Reply With Quote
Old 09-29-2012, 02:17 AM   #2
sdsester's Avatar
You can buy or mix a solution to speed graying of woods like cedar or redwood. Look online for the formula. Cabot's Bleaching Oil is what I used to use and it is a tried and true product for accelerating the weathered look of exterior wood. It has a tiny amount of gray pigment in it. It should work great with your semi-transparent Cape Cod Gray but I forget how soon you can apply the stain. You may actually like the look without the stain? Sikkens probably has a similar product.
sdsester is offline   Reply With Quote
Old 09-29-2012, 02:21 AM   #3
That's great info. I'll check with my local sikkens dealer paint store. How fast does the wood go gray?
Old 09-29-2012, 02:42 AM   #4
sdsester's Avatar
Very quickly and especially since you are starting with kiln dried lumber. Hard to give it to you in hours and minutes since temperature, humidity, sun exposure, moisture content of the wood and all will play a role. You might look up the data sheet on whatever you get to see what it says. Can label may have it also.
Just a comment and I sailed boats with natural grayed teak decks so do not mind the look. Are you sure you want to do this to nice kiln dried cedar though? Just asking and double checking, not judging, I promise. Trimmed out with slick looking railings and so forth I am sure it will look great. This is not a set it and forget it proposition though. You are still going to have to use something on the deck every few years depending on climate.
Old 09-29-2012, 03:06 AM   #5
This is a two tier deck at ground level with about a 7" grade so anywhere you can get off the deck it's 7" off the ground. No railings. Two intersecting L shapes. Small 1951 ranch house with atomic modern style. Deck edge will have a recessed rope/strip light with a steel facia The facia will have thin offsetting rectangular holes cut out so the light casts out. I'm going to let the steel rust out and give me contrast with the gray.
Old 09-29-2012, 03:23 AM   #6
sdsester's Avatar
Sounds nice actually. You might look into some of the newer LED marine lights for decks and stairs as an alternative to rope lights if you need more illumination. Of course there are oodles of programmable LED possibilities now too if you want to change color or brightness.
Laser or water cutting shapes in the steel facia could be fun.
Do post a picture when done?
Old 09-29-2012, 03:35 AM   #7
I have not decided on a lighting solution yet. I'm leaving a 1.5" overhang on the steel facia sides. That should give me enough room for the steel facia and TBD light strips.
The steel hole pattern could be laser, water or plasma cut. I have a local artist piece that provided the inspiration. She may be doing the work.
Old 09-29-2012, 04:13 AM   #8
sdsester's Avatar
That is cool. Many of my clients were galleries but few carry a lot of outdoor pieces. Two of my fave artists were with my fave gallery (although I was supposed to love them all equally). Mark and Mindy---no kidding---were a couple with one doing blacksmith work and the other doing amazingly complex metal chasing. They did some spectacular pieces with another friend who late in life has become really good at studio furniture. Of course one of my super faves blows giant crystal pieces and then carves them up. He sometimes adds oxidized metals like you have in mind.
http://www.cinemagallery.cc/Fekete_A.htm
new second story deck stair, platform question walt1122 Building & Construction 10 11-12-2010 10:52 AM
Need advice on deck flashing, water stain Durt Ferguson General Discussion 4 04-20-2010 06:09 PM
Deck Stain arrghHeadache Painting 1 03-22-2010 10:51 PM
Deck: Do I need to use Stain Remover ( Pics ) mbmonk Painting 11 07-19-2009 12:27 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
