Old 08-10-2010, 08:54 AM   #1
Dick
graffiti on vinyl garage door
I live in a city where gangs spray their territory like dogs and cats.
A new couple that just moved in next door woke up this morning and discovered their garage door covered with gang symbols and crap. I would like to help them.
What is the best way to re-coat vinyl material?
Thanks.
Dick
RMCarner is offline   Reply With Quote
Old 08-11-2010, 07:45 AM   #2
Go to your local PAINT STORE, ask them about Acrylic resin paint used for vinyl application. Big boxed stores will not carry what your in need of product wise. Clean surface with soap and water. Use a light color paint, not a darker color. Vinyl is tricky that way in that if it gets to hot it will buckle or warp. Paint in the shade, not in direct sun light. Also ask them about a good primer for your particular situation. Good Luck.....................
And good job by you for lending a hand to your neighbors .............
mark942 is offline   Reply With Quote
The Following 2 Users Say Thank You to mark942 For This Useful Post:
Gary in WA (08-11-2010), RMCarner (08-11-2010)
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Garage Door Install Opinions detailedEye Building & Construction 4 03-31-2010 11:15 PM
stuck garage door stuckdoor General Discussion 7 08-30-2008 04:30 PM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 12:36 PM
Stanley Garage Door Opener? cibula11 General Discussion 1 05-12-2007 04:02 PM
