Got Interior, What For Exterior ? - Painting - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 11:41 PM   #1
So I asked around and long story short I went with the Valspar Contractor 2000 interior paint.
I've only done one wall to test it out and it went down well, and covered great.
I need to do some exterior painting and for whatever reason Valspar does not make an obvious exterior equivalent.
What would you guys recommend in the same type of price range? The Contractor 2000 runs about 20 a gallon, but I don't know if exterior is typically more expensive.
Also, what do you guys recommend for primer? The walls are just exterior grade plywood so I know primer and paint are important.
TIA!
Briandl is offline   Reply With Quote
Old 05-15-2011, 04:26 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
this will work, if you can get Duron, their Weather Shield is a good exterior product
chrisn is online now   Reply With Quote
Old 05-15-2011, 05:50 AM   #3
Welcome Brian, If you can't get Chrisn's recommendation, get a premium exterior wood primer from one of the big brand names, SW, BM, Cabot's Problem Solver Primer, etc. Oil base will give you the best penetration. As for finish, you could also consider a solid stain in addition to paint. Not sure what you're painting if the exterior walls are just plywood sheathing. How long has the plywood been exposed? What kind of shape is it in? You may want to consider some form of treatment prior to priming. Since the prime coat determines the success of all future coats, if the surface condition isn't optimal, your next coats or the job as a whole won't be either.
Old 05-15-2011, 11:08 AM   #4
It's a situation where some of the exterior grade plywood siding has failed. The paint cracked and water was able to get in and soften the wood.
I need to replace a few panels. Obviously it would be better to replace it with something better, but it's not in the budget at this time.
So these new panels will need to be primed and painted, and the existing panels will also get a scraping and new paint.
I wasn't sure about oil based primer/paint, or even sheen.
As far as I know nobody carries Duron in my area (78249).
Old 05-15-2011, 11:14 AM   #5
If the panels aren't yet installed, back prime them before. San Antonio has to have a SW or BM, go in and explain your situation, ask what they recommend. As to sheen, that's a personal preference.
Old 05-15-2011, 11:57 AM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
If its exterior plywood you could use a solid stain, Cabot ProVT and Sherwin Williams Woodscapes are two good products that are around the same price. With a solid stain you will not have to prime, but you will still apply two coats.
housepaintingny is offline   Reply With Quote
Old 05-15-2011, 03:30 PM   #7
If I'm understanding you correctly I don't want to stain, I want to paint.
Old 05-15-2011, 03:38 PM   #8
Rewards Points: 616
A solid stain gives you a painted look without the use of primer and will not peel/flake like paint down the road.
Old 05-15-2011, 03:48 PM   #9
Brian, solid stain and paint will look basically the same. However, stain will have better characteristics for your application, and it breathes better than primer/paint. Solid stain is a common coating for exterior wood siding of all types. As HPNY stated, it won't require a primer, two coats over bare wood. It will also go over the existing painted surfaces with the proper prep, cleaning, sanding, etc. It's easier, less time consuming, and will probably be more beneficial for you in the long run. Go into a local SW store and talk to them.
Old 05-15-2011, 04:01 PM   #10
I guess I'll have to look into it. I'm used to associating stain with the type of semi-clear stuff you put on decks and furniture etc.
Just to give you an idea of what I'm dealing with I'm attaching a picture. I basically need to replace the pieces that have rotted out. I'd love to re-do the whole thing but I don't think it's in the budget right now.
Is this something I can get at the big box stores or would I need to go to a SW type place?
Old 05-15-2011, 04:07 PM   #11
I know that Lowe's carries Cabot's. If you go to Cabot's website, you can find a store locator in your zip code. Remember, back stain your siding before install, if not done already.
Old 05-15-2011, 04:18 PM   #12
You mean to stain both sides right?
Old 05-15-2011, 05:09 PM   #13
For whatever it's worth the reviews on Lowe's for Cabots are pretty terrible. Mainly issues with peeling. Am I correct to assume they make a base that I can get tinted to match any color, because the color selection on their website is better than what SW has but still not what I'm looking for.
Old 05-15-2011, 05:54 PM   #14
Brian, for what it's worth, I'm sure the reviews on Lowe's are from HO's. In all honesty, with no disrespect, I don't put much stock in a ho's opinion about paint products. Here's the reason, about 50% of the pro painters I know don't know their backside from a hole in the ground, and they can barely pull of a quality job, and usually it's by stroke of luck. Coating applications require sound, well prepared surfaces. It also requires a basic understanding of weather, environment, moisture, construction, paints/chemicals, substrates, etc. There are so many variables that can cause paint failure, and they can usually be traced back to human error, whether it's a plain lack of knowledge or willful disregard. That's where the knowledge comes in. I've worked for numerous painters over the years and watched, more times than are countable, applications being done that were doomed before the paint was put away. A general contractor friend/colleague told me that Sikkens stain sucks, I asked him why. It failed on his deck. Turns out his deck sits on the ground and he used a product not spec'd for decks with less than 18" clearance from the ground, which it clearly states. A painter friend, a painter, told me the same of Sikkens. Turns out he put a product on a hardwood deck, but he didn't use the lacquer thinner or acetone during the application, as the instructions require. An HO customer of mine does his deck with CWF every two years, by which time the deck is completely stripped by the sun. Why, he rolls it on and doesn't get the sides of the boards, which is a wide open door for moisture. Plus, when you roll with no back brush, the finish doesn't penetrate properly and basically lays on the surface. He thinks that CWF is a bad product. Coating companies don't just throw stuff in a can and hope it works. The products are put through extensive testing. I'm far from a believer in everything the paint companies claim, believe me. But, I'm more inclined to believe that a product failed because of poor prep, faulty application technique, poor choice of product for the job's requirement, or lack of subsequent maintenance routines. You can have Cabot's or SW stains made in practically any color you like. I've done jobs with Cabot's done in BM colors. And, just the other day I was told SW could be made in practically any color in the fan deck. Lowe's or HD may only make it in the company offered colors, but the paint stores will make thier own colors.
Old 05-15-2011, 06:18 PM   #15
Yes, that prevents moisture that transfers through the walls from the inside from penetrating the back of the sheathing and being pulled through the exterior surface, taking the stain with it. A common source of exterior coating failure. Knowledge
