A Good Paint Stripper - Painting - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 12:02 PM   #1
Rewards Points: 321
a good paint stripper
Does anyone know what the best paint stripper is for getting about two coats off of old pine window molding and baseboards? Thanx, Jean
DIherself is offline   Reply With Quote
Old 04-26-2011, 12:38 PM   #2
Gymschu's Avatar
Rewards Points: 230
I do, but it is very caustic to use. To be on the safe side, try one of the citrus removers. Be patient, let it work and two layers should come off fairly easily. I usually apply some, cover it with plastic or Saran Wrap and let it work. Of course you might want to test for lead before you get too carried away.
Old 04-26-2011, 12:58 PM   #3
Rewards Points: 321
pardon my newbie-ness, but since the molding is vertical, won't it drip off? And I can't imagine how to make saran wrap stay on there. If you tell me the caustic way, I promise I'll be careful. There's more windows in the room than wall, and I'll open them all and let the air in...
Old 04-26-2011, 02:59 PM   #4
Gymschu's Avatar
Rewards Points: 230
Most paint strippers are thick, gel-like substances and will stick to vertical surfaces. Saran wrap can be place over top of the stripper to keep it from drying out. Trust me, you don't want the harsh chemical strippers in your house........any drips on your skin will burn and the noxious fumes will harm your lungs without a respirator.
Old 04-26-2011, 03:08 PM   #5
Rewards Points: 321
okay. Thanx for writing me back. I'll try the citrus.
Old 04-26-2011, 03:22 PM   #6
Too Short? Cut it Again!
Some of the newer strippers are gels and will stick well to vertical surfaces.
Another gift from God still somewhat new to the market is an infrared stripper. It will heat multiple layers of paint and allow you to scrape them right off with minimal fire risk. You can rent a good one from a toolyard. Somewhat tricky to use on trim though.
What are you hoping to gain by the way? Not often does stripping painted pine lead to the bare wood look you were hoping for in my experience. Worth a shot I guess if you think only two coats are on their.
Remember if it is older it might have lead content.
Old 04-26-2011, 03:46 PM   #7
And sorry, I sometimes forget the obvious. With only two layers of paint your fastest stripping method may be scrapers with really sharp blades. If you can get it off this way you also avoid the heat generated from chemical, abrasive, infrared, etc. stripping methods that can melt paint into the grain of soft woods like pine.
If the pine was painted the way it should be with a good primer, and especially one sealing and penetrating, you will have trouble getting it out of the grain. Try stripping it down though. Then shellac. Then strip the shellac and see if it pulls pigment in the grain out.
Old 04-26-2011, 04:51 PM   #8
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Peel Away is a safe stripper to use and there are no fumes.
housepaintingny is offline   Reply With Quote
Old 04-26-2011, 08:30 PM   #9
Stairguy
Millertyme's Avatar
Rewards Points: 508
from my experiences i have realized that anything that is environmentally safe does not work very well. For me, peel away, doest get through the tough stuff. For the tougher stuff I use strip-ease. It seems to work the best.
Millertyme is offline   Reply With Quote
Old 04-26-2011, 08:33 PM   #10
Rewards Points: 616
We generally use strpeese too, but if someone is looking for a less caustic, safer alternative peel away will work if you follow the instructions.
Old 04-27-2011, 02:05 PM   #11
Rewards Points: 321
thank you all. The paint is literally falling off the wood by itself (that's how long it's been!) and that's how I can see how pretty the wood is underneath the two coats. I just want to get it down to the wood; then I will have to research what kind of stain or oil to use to protect the wood. I think my house will sell better if the buyer can see the good wood, and then they can paint it whatever color they want. Just an idea...
Old 04-27-2011, 02:09 PM   #12
Rewards Points: 321
Oh, and I did scrape as much as I possibly could with a sharp scraper. There's still too much paint on there. I tried to sand it, but the paint won't budge, so I think I'm going to have to use a chemical stripper. At least I have a few products to try, thanks to you all.
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
What would be good quality paint kenny357 Painting 13 06-07-2007 02:36 AM
