Good Floor Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 11-02-2005, 09:15 PM   #1
Good floor paint?
Hi all.
I'm building a 24x36, 2 story detached garage. The second floor decking is Advantech osb subfloor, but I don't plan on putting any additional floor covering over it.
I should have it decked this weekend, and the weather should be nice enough to get some paint on it. I want it painted both for short term protection from the elements as I'm building the roof, and long-term wear protection.
Since I'll have just a nice big flat surface before I start framing the roof, it should be an ideal time to just roll on some paint.
I'd like something moderately priced and not too slippery.
Any suggestions?
Don
DonNH is offline   Reply With Quote
Old 11-03-2005, 07:16 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
I haven't specifically tried it on Advantech osb subfloor, but the Ben Moore's Porch and Patio is very good
I use it inside and out (though out is usually on small balconies and stuff, I use solid deck stain for anything bigger)
I've probably used it on everything else, wood, concrete, new, prev painted, walls (commercial bathrooms-this stuff is tuff)
If it will be exposed for a while, then covered, I wouldn't have any problem recommending it
Just not for garage floors where there's oil in the concrete
slickshift is offline   Reply With Quote
Old 05-22-2006, 06:00 PM   #3
Painting Contractor
I recommend Sherwin Williams Prep-Rite primer. I would personally go with either ProBlock or their All Surface Enamel Latex Primer. Then a topcoat of their All Surface Enamel, preferably the oil based one they offer. These 2 products are incredibly durable, especially for flooring. Just talk to your local Sherwin Williams reps and I'm sure you'll be happy. And a tip: you said "roll on some paint"...make sure you always backbrush when you roll the paint on for proper adhesion. Good luck, let me know how it goes.....
Paintguy26 is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 09:23 PM
Trim Tramp : Good or Bad? KUIPORNG Carpentry 16 09-10-2013 10:54 AM
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
What would be good quality paint kenny357 Painting 13 06-07-2007 01:36 AM
Good inexpensive 10" miter saw for a DIY'ER??/ Sellncars Tools 19 09-26-2006 12:17 PM
