-   -   good brushes (http://www.diychatroom.com/f4/good-brushes-8959/)
firsthomegal 06-05-2007 10:44 AM
good brushes
I haven't done a lot of house painting, but I know that I hate the job if I am working with lousey brushes. But I never know what to get.
What brushes do people recommend for an exterior paint job?
poppameth 06-05-2007 11:33 AM
I like Wooster Ultra Pro Xtra Firm. Solid Nylon+ bristle. Clears up easy and has plenty of firmness for these heavy bodied exterior acrylics. You can also use these in various brush cleaning solutions without melting the bristle as will happen with polyester.
slickshift 06-06-2007 03:31 PM
Depends on what the product I'm applying is, and what the house material is
For painting trim or clapboard, I generally prefer a big fat 3" Purdy XL Swan
keyser soze 06-07-2007 06:33 AM
Sorry to hijack but I was about to post a thread about good brushes. What about a good one for interior latex (semi gloss)? I like an angled brush for cutting in for sure, and when I first started my project I foolishly assumed the 3 packs for $8 at Homie Depot were fine. I have one decent one at the house that I purchased a few months ago, I forgot the brand though. It was definitely a big step up from the cheapos.
Also, what would someone do to keep the brush working like new? I rinse them out very well at the end of each coat (or anytime I'm taking a lunch break etc). Are there other ways to keep them happy?
Thanks for any advice!
J187 06-07-2007 07:57 AM
Cutting in brush for me is a nice 2.5" angle sash purdy. For other work, depends on what I'm painting for the size but its always a purdy of some kind. I haven't liked any other brushes that I've used.
poppameth 06-07-2007 12:16 PM
It's really all opinion. I can't stand Purdy myself, but plenty of other people like them. I'd just make sure you get something with a bristle stiff enough for the paint you are using. Heavier paints need a stiffer bristle to push them out. Lighter bodied paints can do with a softer bristle. Also make sure the tip is beveled and not cut flat across the end.. Press the tip against a flat surface and make sure the bristle lay down to a nice chiseled edge when they flex. flat cut brushes are too thick at the tip and don't allow for clean lines. Outside of that, just stick to a good brand. Purdy and Wooster are two of the most widely known. Just be advised that the Wooster brushes Lowes carries are NOT the same as a true Wooster brush. I compared them to the ones I carry and they look like the have half as much bristle in the. Flimsy junk. I'd go to a real paint store for my brushes just to be safe.
keyser soze 06-07-2007 03:46 PM
That just advanced my brush knowledge by years. Thanks guys!
slickshift 06-07-2007 04:59 PM
I like a firmer brush for that myself
I like the Corona Cortez 2.5" Sash (angle)
The Purdy's are good too, but the Coronas are firmer
As mentioned, it is a Different (brush) strokes for different (brush) folks kinda deal, but both are good
Also, in addition to the Lowes/Wooster warning poppa posted, please be advised the Purdys at Home depot are also de-spec'd
Go to a real Paint Store for the good ones
Well, in addition to rinsing them out, I use a wire brush, a brush comb, and a spinner
I use the wide one, second from the left
http://media.popularmechanics.com/im...brushes-lg.jpg
It's pretty big and wide so it works pretty quickly
The comb is something similar to this:
http://www.hardwarestore.com/media/p...8_front200.jpg
Helps get the paint out of the bristles near the ferrule (metal)
And really helps straighten out the bristles after I use the spinner
http://www.hardwarestore.com/media/p...7_front500.jpg
After I wet comb and wire brush, then wet spin a few times, I'll comb the bristles straight then put it in it's shuck (cardboard "keeper" it came with) to dry
poppameth 06-08-2007 05:58 AM
You must be an allway fan too! I've started carrying a lot of their stuff instead of Hyde and Warner. Better price and in most cases better quality.
Workaholic 06-08-2007 04:56 PM
I use primarily purdy's, prefer the xl swan's I do most of my cut in with either a 3.1/2 or a 4. Though that could be mostly old school. I find most prefer a 3" brsh so gey yourself a 3 xl swan.
