#1 |
Good Air Gun Sprayer for DIY'er exterior home painting
Hello Friends,
So what's a good spray system for a DIY'r such as myself for painting the exterior of my house? In 99-2003 I worked in a specialty gas manufacturing plant and worked in the paint shop painting all different sized steel cylinders of all different weights as well. They had a kickin' system, Graco gun and pump system where you put the pump right on a 5 Gal bucket of latex paint. It fed back to one of the main compressors. It worked great. However, I can't get maneuver a 5 Gal bucket on a ladder so I'm wondering why the pro's use. My house isn't two stories so I won’t necessarily need scaffolding. I do have a 40-50 gal air compressor and can use that. I'm open to suggestions. I will be using most likely a latex stain or paint. Suggestions on a decent, quality portable spray system? Thanks, ~S |
#2 | |
Good Air Gun Sprayer for DIY'er exterior home paintingQuote:
Forgot to add the link sorry, http://www.cjspray.com/homeowner-spr...er-262800.html You don't want/need an air compressor with one of these units,but you do need to back roll. Last edited by Canarywood1; 12-07-2012 at 07:04 PM. |
#3 |
Really need an airless spray unit, Unless you have used one before you can make a real mess a whole lot faster.
Unless your willing to spend at least $400.00 your going to spend way to much time playing with it trying to get it to work. If you really want to do this and it's the only job you have for it you may want to try renting one. With an airless the unit sits on the ground and you use long hoses with the gun attached. Last edited by joecaption; 12-07-2012 at 06:30 PM. |
| Display Modes | |
| Questions about painting and possibly adding siding to stucco house? | krm27 | Painting | 3 | 01-19-2010 01:22 PM |
| Car Painting and sanding | h3llfir3 | Painting | 19 | 08-11-2009 10:44 PM |
| Car Painting and sanding | h3llfir3 | Automotive Repairs | 1 | 08-10-2009 11:02 PM |
| painting my garage floor (and some outdoor slabs) - are these any good? | joeyboy | Flooring | 2 | 10-17-2007 09:13 PM |
| How to identify a good painting contractor? | firsthomegal | Painting | 8 | 09-17-2007 07:11 PM |
