Glossy Textured Interior Walls - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 08:59 AM   #16
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
who the heck cares if texture is a regional thing... you can do what the drones do and have your home like "everyone else" in the region, or you can be unique and do something different. Its ok to put any type of texture on a painted service, you just have to be careful as texture is water based and it will take alot longer to absorb into the walls before painting. Are you planning on contracting a professional texture company or diy? I do this for a living and own all types of texture machines from hoppers to trailer mounted spray rigs. if you need help, just ask.
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 08-07-2011, 02:10 PM   #17
Smile
I'll reclean the wals with a wall cleaner, rewash with TSP and rinse well and use the Zinsser product. Thanks a bunch!
Originally Posted by ltd View Post
how old is this house ,what finish is on their now?oil or latex ? is lead paint an issue? hers what i would clean walls when you use any cleaner it is important to rinse wit clean water .the residue left by not rinsing is as bad as what your cleaning,. im not knocking big orange but yes you can paint latex over oil primer. zinsser cover stain oil about 22 dollars at the big box. this will stick and if their are any stains well that's that .i think the can says top coat in 2 hours id let it dry over night
susan henderson is offline   Reply With Quote
Old 08-07-2011, 02:12 PM   #18
Just rewash the walls with the TSP and rinse. You don't need two separate washings.
Old 08-07-2011, 02:16 PM   #19
**** Thanks Stoner, house will be done in Art Deco style, old Hollywood. Will use a latex testure and some walls will be imported wall paper. Previously used a product, ATI rough stuff, appears it's discontinued. Drying is not a problem, I work really slow! Can you recommend a good texture product that will work over the oil base primer (Zissner).
Old 08-08-2011, 07:50 PM   #20
stoner529's Avatar
Rewards Points: 154
depends on if you want to spray the texture on. what tools are you using? you can get texture cheaper at supply yards depending on where you are from
The Following User Says Thank You to stoner529 For This Useful Post:
susan henderson (08-13-2011)
Old 08-13-2011, 12:58 PM   #21
wall texture
Stoner, can you recomend a texture? Previously used ATI product waterbased 'rough stuff'. Apparently company is out of biz. Will use trowel. Walls are now primed with Kilz oil priner and I'm glad to have the recommendation of the oil, it covered well. Susan
Old 08-13-2011, 04:23 PM   #22
m1951mm's Avatar
You are talking about texture and trowels. Have you thought about Venetian Plaster or other similar products that are trowled on and can be painted after or the substance can be colored prior to application and blended.
Two good suppliers of these products are Faux Like a Pro and Aqua Effects. I do a ton of trowled on finishes and they are WONDERFUL!!!
If you care to look at my picture sharing site/ www.picturetrail.com/mickey51
you can see some of those products in action.
What texture are you looking for??
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
susan henderson (08-14-2011)
Old 08-14-2011, 01:47 PM   #23
Decided not to trowel
Will use a textured roller, the blue texture cover. Can you advise a good economical water based texture? Will be doing the entire house. 5 Gal qty would work best. Previously used ATI waterbased Rough Stuff, appears to be discontinued. Mickey, I was unable to open your pitcure link. Susan
Old 08-20-2011, 03:54 AM   #24
m1951mm's Avatar
Took some pics of a Venetian Plaster sample board as and FYI to show what can be done with a wall that has a bad texture and make it a show case IMHO
glossy textured  interior walls-8-16-2011-012.jpg   glossy textured  interior walls-8-16-2011-011.jpg
Mickey
Fantasy Walls and Windows
Tags
covering gloss texture
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Painting Textured ceilings? very textured! and walls Slickit Remodeling 3 06-11-2009 07:12 PM
painting over a textured ceiling tmtch540i Painting 1 04-04-2009 06:00 PM
Repainting glossy exterior crescentpr Painting 8 06-04-2008 06:54 PM
Where glossy and flat meet drhowarddrfine Painting 4 07-03-2007 05:43 PM
