glossy textured interior walls
1 Attachment(s)
Hi, bought a fixer foreclosure with all rooms painted bright colors. Walls appear to have a heavy gloss over texture. Have used TSP and sanded w/ orbital sander and primed with water base Kilz. Noticed some of the primer has an orange peel look and having problems with priner sticking. Want to prime and then apply a heavy texture, concerned about the texture sticking. Researched Zinsser Bullseye, both products say they will cover. Considering purchasing another orbital sander and really leaning on the walls and ceiling to degloss for better grip. Please provide recommendations on additional sanding,andif I should use an oil based product or water based, appears Kilz and Bullseye are comperable. Home Depot advised against a oil based primer as latex won't stick to oil based primer. Thanks! Susan.
how old is this house ,what finish is on their now?oil or latex ? is lead paint an issue? hers what i would clean walls when you use any cleaner it is important to rinse wit clean water .the residue left by not rinsing is as bad as what your cleaning,. im not knocking big orange:no: but yes you can paint latex over oil primer. zinsser cover stain oil about 22 dollars at the big box. this will stick and if their are any stains well that's that .i think the can says top coat in 2 hours id let it dry over night:wink:
The sander is overkill. If the primer isn't sticking, there is something else going on. I suspect it might have contaminates- greasy walls or something.
I would recommend washing it down with something like Dirtex, or Krud Kutter. Some would say TSP, but that is better at breaking the gloss than cleaning the walls, and it is somewhat tricky because it will etch anything it gets on. BTW- Kilz latex is trumped by Zinsser 123 or bulls eye... |
I agree that sanding as you are is overkill. When you say you're having trouble with primer sticking, what does that mean? Bonding primers can take up to 5 days or so to develop their bond, and in the meantime will chip and come off easily. Washing with TSP, as Brush said, will etch the surface, which will be easier than sanding a textured surface. Me, on walls, I would just trust the bonding primer to do the heavy lifting, and just go over the gloss with the primer. Trim is different. But, if you wash with TSP, be sure to rinse well, especially if you are using a Zinsser product. They spec against TSP, but it's only because people don't rinse well enough. Product knowledge, lack of, is a troublesome aspect of the big boxes. Many of them were selling garden hoses last week and graduated to paint. I don't think that I've ever seen a general purpose oil based primer that wouldn't accept a latex topcoat. Not saying there aren't, just haven't seen one, for non-commercial, non-idustrial uses that is. An oil would be your better choice to use under a water based texture finish, less chance of re-activating the primer. I would give it a couple of days to dry prior to texturing. Use Zinsser Cover Stain or BIN. Good Luck.
Joe |
Thanks, Joe, I used a heavy mixture of TSP and unfortunately did not rinse. I believe the 'not sticking' could be from greasy dirt, as the house was really trashed. The primer has been on over a week, house is in Las Vegas and gets very hot, so might be drying too fast, since I don't run the air. So, taking your advice, I'll re-wash the walls with the cleaner, re-prime with oil base, and wait a week before applying a latex texture. Can you recommend a few texture products? Thanks, Susan.
I am a flat wall kinda guy- so can't help with the texture mix- sorry.
Hi LTD, House is 14 years old, the finish appears to be a hard gloss, very thick. Is there a way to tell if the paint was oil base? I'm doing a re-wash with cleaner, as per Joe. Glad to hear it's OK to go over the oil with a latex base. Thanks for your input!
Thanks, I'll test the wall and find out what's on it. Good tip!
Out here, in the west, I don't see much in wall coat except texture. Some is knockdown and some is straight spray without knockdown. I'm in CA, AZ and NV.
| All times are GMT -4. The time now is 09:51 PM. |
