Glazing Over High Gloss Paint - Painting - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 09:41 PM   #1
Glazing over high gloss paint
I painted my kitchen cabinets bright white with high gloss paint. I want to glaze over them. What do I have to do to make the glaze stick without sanding them down?
kntry is offline   Reply With Quote
Old 01-27-2010, 04:05 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Why would you want to do that?
Old 01-27-2010, 05:32 AM   #3
Too Short? Cut it Again!
I an not sure I understand either and why you used a high gloss paint if you knew you were going to put a glaze over it?
In any event, ONCE THE PAINT HAS FULLY CURED you can hit it with a chemical deglosser and the glaze should stick. If you use the deglosser before the paint has cured you could end up with a mess.
I think you will want to stick with a compatible glaze---latex/acrylic if that is what you put on the cabinets or oil if that is what you used.
Old 01-27-2010, 09:16 AM   #4
I'm sorry for not being more specific.
I painted the cabinets about 8 years ago. I have several large dogs (one that jumps against the cabinets) and 2 sons that are not exactly careful. Over the years, the cabinets have stained with car grease around the handles and there are chips here and there.
We're getting ready to move and I want the quickest and easiest fix to spruce them up to look good for the renters. I thought if I went over them with a chocolate glaze, it would accentuate the few chips to make them look old (the house is 34 years old) and hide some of the other imperfections.
sanding vs liquid sander for high gloss egzh Painting 5 06-25-2009 07:59 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
does high quality bargain paint exist? erica Painting 6 06-22-2005 06:53 AM
