Old 10-15-2012, 12:35 AM   #1
giving wood the grey aged look
hey all. so ive been working on my coffee table project for a while now.
i want to age the wood so that it turns grey. i heard soaking 00000 steel wool in white vinegar makes a nice solution to turn the wood grey.
ive been soaking the steel wool in the vinegar for 2 days and the wool is pretty much intact and the vinegar still clear. i used distilled white vinegar... would that make a difference?
thanks
joshik is offline   Reply With Quote
Old 10-15-2012, 01:53 AM   #2
Did you try this yet. I have never seen it done with vinegar. What type of wood is this made out of?
Ishande is offline   Reply With Quote
Old 10-15-2012, 01:54 AM   #3
i havent used it yet. i just read a bunch of posts talking about steel wool and vinegar.
it is redwood from sold old picnic tables that i had.
i actually found a product called Eco Wood that will age wood to a nice grey.
Old 10-15-2012, 10:43 AM   #4
would not a gray semi transparent stain work it would be gray and you would still have the wood grain? There are a lot of guys on here more experienced with stain than I am so i'm sure they will have an answer.
Old 10-15-2012, 10:49 AM   #5
bbo
found a link that also has tea as an ingredient.
let steel wool and vinegar sit for a day.
brush tea solution on wood.
let dry
brush sw/Vinegar solution on wood.
http://www.craftaholicsanonymous.net...from-que-linda
let us know if this works.
bbo is offline   Reply With Quote
Old 10-15-2012, 04:02 PM   #6
Rubbin walls since'79
Brushjockey's Avatar
Someone- I think Cabots- has a greying solution. Been a long time since I used it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 10-15-2012, 06:14 PM   #7
sdsester's Avatar
Indeed it does and I posted about last week or so. I will see if I can find it again and post an image of the can. It is called Bleaching Stain or Bleaching Oil and greys wood (cannot remember). It also has a minor amount of grey pigment in it. I used to use it on redwood fencing in N California when clients wanted an accelerated look or to blend in for sprinkler overspray damage before applying a semi-transparent stain.
Found it. It looks like it runs $43/gallon retail. You can probably look online for a formula to make your own cheaper?
sdsester is offline   Reply With Quote
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Vent Noise - Rubbing Wood; Seeking Advice steveo_1978 Plumbing 4 01-22-2010 11:26 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
Giving wood floors a new finish MystiLatte Flooring 1 04-20-2008 06:53 PM
