-   -   giving wood the grey aged look (http://www.diychatroom.com/f4/giving-wood-grey-aged-look-160116/)
joshik 10-15-2012 12:35 AM
hey all. so ive been working on my coffee table project for a while now.
i want to age the wood so that it turns grey. i heard soaking 00000 steel wool in white vinegar makes a nice solution to turn the wood grey.
ive been soaking the steel wool in the vinegar for 2 days and the wool is pretty much intact and the vinegar still clear. i used distilled white vinegar... would that make a difference?
thanks
Ishande 10-15-2012 01:53 AM
Did you try this yet. I have never seen it done with vinegar. What type of wood is this made out of?
joshik 10-15-2012 01:54 AM
i havent used it yet. i just read a bunch of posts talking about steel wool and vinegar.
it is redwood from sold old picnic tables that i had.
i actually found a product called Eco Wood that will age wood to a nice grey.
ToolSeeker 10-15-2012 10:43 AM
would not a gray semi transparent stain work it would be gray and you would still have the wood grain? There are a lot of guys on here more experienced with stain than I am so i'm sure they will have an answer.
bbo 10-15-2012 10:49 AM
found a link that also has tea as an ingredient.
let steel wool and vinegar sit for a day.
brush tea solution on wood.
let dry
brush sw/Vinegar solution on wood.
http://www.craftaholicsanonymous.net...from-que-linda
let us know if this works.
Brushjockey 10-15-2012 04:02 PM
Someone- I think Cabots- has a greying solution. Been a long time since I used it.
user1007 10-15-2012 06:14 PM
Indeed it does and I posted about last week or so. I will see if I can find it again and post an image of the can. It is called Bleaching Stain or Bleaching Oil and greys wood (cannot remember). It also has a minor amount of grey pigment in it. I used to use it on redwood fencing in N California when clients wanted an accelerated look or to blend in for sprinkler overspray damage before applying a semi-transparent stain.
Found it. It looks like it runs $43/gallon retail. You can probably look online for a formula to make your own cheaper?
http://cdn2.bigcommerce.com/server60....1280.1280.png
