Getting Rid Of Roller Marks - Painting - DIY Chatroom Home Improvement Forum
Old 09-28-2008, 04:49 PM   #1
Getting rid of roller marks
Hi - I have decided to repaint my living room as when the previous owners painted, they left roller marks on the wall. I was hoping that the new coat of paint (an olive green) was going to be enough to cover up the marks, but they are still quite visible. Any suggestions?
Cheers!
fts123 is offline   Reply With Quote
Old 09-28-2008, 06:51 PM   #2
Rewards Points: 1,766
Depending how high the ridges are, you might try sanding them smooth, using some drywall compound to smooth over them, or if lucky, use flat paint to minimize reflections from any remaining ridges.
bob22 is offline   Reply With Quote
Old 09-29-2008, 08:21 AM   #3
Rewards Points: 506
I agree that a decent sanding would help. You may also may want to try priming with a nice, thick, water-base primer if the current topcoat isn't sanding well. I use Sherwin Williams PrepRite Pro Block Latex. It goes on with a pretty high build, so super-minor surface defects get covered up pretty well and it sands easily. (Far easier than a topcoat.)
As a side note, the three biggest causes of roller marks are:
1) Cheap and/or too thin covers. Use nothing less than a 3/8" Purdy White Dove. If it's thinner and/or cheaper, it won't work.
2) Poor quality paint. Use paint at or near the top of the product line from an actual paint store. (NOT BigBoxCo.)
3) "squeezing" paint out of the roller. Just "lay" the roller on the wall, and apply paint in a single 8'-10' stripe. Don't try and stretch the roller load too far, and let the roller do the work, not your amrs.
SirWired
sirwired is offline   Reply With Quote
Old 09-29-2008, 02:43 PM   #4
Thanks for the suggestions! I will try sanding for sure. Thanks also for the tips of how to avoid roller marks...I definitely use those as I don't want to run into this problem again.
How do you use a loop roller? redline Painting 8 04-02-2013 09:05 AM
Best way to cut in and not leave brush marks? twilightcall Painting 14 02-17-2012 03:19 AM
How to remove grey marks on porcelain stool... RippySkippy Plumbing 1 06-16-2008 09:02 AM
Roller Marks jfarringdon Painting 4 09-28-2007 06:48 AM
Roller Marks - Please Help andru04499 Painting 3 09-16-2007 08:53 PM
