Getting Ready To Paint Some Walls However... - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2006, 04:00 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 510
Getting ready to paint some walls however...
The previous owner decided it would be a good idea to screw some enormous, horrible looking shelves into the walls in the dining room. He used 1/2" wall anchors - the metal ones that spread behind the wall.
I got those out but they left behind their 1/2" holes.
There are rows of holes. There are groups of 4 holes, like this
OO OO
OO OO
OO OO
OO OO
they are every 12" from the ceiling to the floor.
The walls are plaster, my question is, how should I go about filling these before paint. Do I need to put a backer or can I just spackle the 1/2" holes. Putting a backer might be a PITA considering there are like 60 holes between the 4 walls that anchored the shelves - on two of the face walls only one hole held the side of the shelf and they were spaced every 24 inches or something. Thanks.
J187 is offline   Reply With Quote
Old 07-20-2006, 04:49 PM   #2
J187's Avatar
Rewards Points: 510
oh, also, about the walls...
The wall on the left which has sets of 4 is only about 4 feet wide with the holes covering about 2 feet of it. The face wall which has the single holes has a window in the middle and is about 8 feet wide and the right side wall has sets of 4 as well, only about 2 feet of it has holes, the wall runs the whole length of the dining room and living room.
Old 07-21-2006, 03:11 PM   #3
J187's Avatar
Rewards Points: 510
Bump
I can try to spackle them later on, I bought spackling today. but I'd love to have a backup plan in place - any advice?
Old 07-21-2006, 05:12 PM   #4
Spackle is the way to go on this one I would think. Plus, with that many holes in the walls, it's going to be the fastest route.
ChrisF79 is offline   Reply With Quote
Old 07-21-2006, 05:13 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Sorry J187, I think I mentioned I don't see much plaster
But what type of spackle did you get?
Was it the lightweight latex (almost fluffy) kind?
I've used that on almost everything with success
Your holes might be a little big for that, but it might work
slickshift is offline   Reply With Quote
Old 07-21-2006, 09:04 PM   #6
J187's Avatar
Rewards Points: 510
I think they might be a bit big. Grrr. I tried to fill em w/ spackling but after it dried fully, It didn't hold very well. There is no way I see to create a backing, am I going to have to cut this wall back to the studs and try to shim a drywall patch in here? That might suck, the plaster guys were definitely drunk when they did these walls, the thickness variations are crazy! Hey, what If I mixed up a little extra thick durabond compound and filled w/ that? Anyone think that would work?
Old 07-21-2006, 09:28 PM   #7
J187, I've used durabond to patch plaster and it worked fine. It doesn't shrink when it dries. I have used the fiberglass tape with it also. I know that's not the correct way to repair plaster, but it has held up fine in my parents house.
randalg is offline   Reply With Quote
Old 07-22-2006, 04:28 PM   #8
A couple of coats of Durabond & you'll be ready for paint.
Kennedy is offline   Reply With Quote
Old 07-22-2006, 09:09 PM   #9
J187's Avatar
Rewards Points: 510
I've used durabond before, and I know that it can get pretty hard and dries fast. But wow, these were some pretty big holes and I feel like now they could stop bullets! I mashed durabond in each hole pretty good, after mixing it a bit on the thicker side. Its 85% dry now and strong as ever. I was worried because I know durabond tends to shrink a bit more than spackling, but it worked perfectly.
Old 07-23-2006, 04:24 PM   #10
slickshift's Avatar
Originally Posted by J187
... I mashed durabond in each hole pretty good...it worked perfectly.
Sweet
I'll have to remember that durabond for plaster if I ever run across any
is it okay to paint walls on winter season? jrgarma Painting 25 01-13-2016 05:42 PM
How to lighten paint on walls kathyswims Painting 5 07-02-2007 03:25 AM
Have oak trim everywhere, what paint on walls? Mr. Michael Painting 6 01-24-2007 05:12 PM
Paint Gun - On Interior walls Leenders Painting 4 10-20-2006 04:16 PM
