Getting Ready To Paint..... - Painting - DIY Chatroom Home Improvement Forum
Old 12-31-2008, 09:52 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Getting ready to paint.....
I am about to start painting my basement.
I assume I start with the trim first? Are there different types of paint for the trim that I need to use?
As for the walls, I have been doing some research on how to paint walls, and some say to first paint a "W" and them spread, and some say just start at one end of the wall and go straight up and down.
I am a newbie at this and would like to know what would be the best method for me to do.
I will prime first with a drywall primer as my basement has bare drywall on it now. I assume 1 coat will suffice?
I am also aware that I have to cut in at the top and on any edges.
Thanks for any help.
yummy mummy is offline   Reply With Quote
Old 12-31-2008, 11:03 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Most times you do the trim last. Your wall paint is going to drip all over the baseboards. Not necessarily the big drips, but the little speckles from the roller. The "W" method for rolling is really if you don't have a roller pole for your roller arm. Take a broom handle and screw it on there so you have a nice pole to work with. It keeps your hands further away from the roller so it is less messy and then you can do long strokes from top to bottom. That will give you your best results and a much more even paint job. Start towards the middle vertically and about 6" from where you just left off painting or from a corner. Run out about an entire roller width from there and then roll back to blend it with where you left off.
Old 12-31-2008, 02:47 PM   #3
Rewards Points: 506
Nobody here has really been able to figure out that "W" pattern stuff. All it does is make your arm sore. I suspect the DIY books recommend it because it could help to hide roller marks if you have poor materials or technique.
One coat primer. (water-base should be fine, unless you have oil paint on the wall now.)
Two coats paint.
Some do trim first, some last. Personally, I do it last.
For best results use top, or near-top paint from a paint store (not big-box), and use a high-quality cover. The 3/8" Purdy White dove is cheap, good, and available everywhere.
One roller load can cover one 8'-10' stripe, no more. Go up, and down once; up and down the previous stripe, reload and move on. Let the roller do the work; if you "squeeze" the paint out of the roller, you WILL end up with roller marks.
SirWired
sirwired is offline   Reply With Quote
Old 12-31-2008, 10:17 PM   #4
Thanks for the explanations and the tips.
I will try and see how it goes.
I think I will do the trim last, so i can avoid the drips or splatters.
Old 01-01-2009, 09:52 PM   #5
onlinehandyman
Rewards Points: 125
some suggestions
I would begin with the trim although I have seen others paint walls first. Primer is definitely a must. ....Have fun!
Last edited by AtlanticWBConst.; 01-06-2009 at 05:16 AM. Reason: SITE RULES VIOLATION: Link Removed from Signature Line
onlinehandyman is offline   Reply With Quote
Old 01-02-2009, 12:39 AM   #6
paint
paint trim last
FieldersChoice is offline   Reply With Quote
Old 01-02-2009, 10:41 AM   #7
Thanks onlinehandyman, I will take a look.
Old 01-02-2009, 04:54 PM   #8
Rewards Points: 556
Yeah, I always paint the trim last. It's easier to tape it off and get a clean break that way.
kcrossley2 is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
