Getting Paint To Stick To Pressure-treated Lumber? - Painting - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 07:24 PM   #1
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
Getting paint to stick to pressure-treated lumber?
There is a 2"x8" strip of pressure treated lumber that basically is a ledger that was used to build a small add-on deck/step and mudroom on the side of the house. The house trim is white, and the previous owner who did this attempted to paint it but of course it is all peeling off. It looks like hell, and it is the first thing people see when they enter the house.
I can't pull the board out without tearing down the whole add-on. All I really want to do is clean it up and get it white (if I can). Is there anything I can do to accomplish this?
Thunder Chicken is offline   Reply With Quote
Old 05-08-2012, 10:12 PM   #2
Rewards Points: 12,878
Use soild colored stain instead.
Cabot or Olympic have worked great for me.
It will say fence and deck stain on the can.
Old 05-09-2012, 03:25 AM   #3
Rewards Points: 626
Use a good Primer for wood two coats of primer then two coats of paint and your good to go!
Nailbags is offline   Reply With Quote
Old 05-09-2012, 07:47 AM   #4
Gymschu's Avatar
Rewards Points: 242
If you have some basic carpentry skills, you could nail a piece of hardie plank over top of the treated piece and paint it. I've done this in the past with great success. Saves you the trouble of scraping, priming, etc.
Gymschu is online now   Reply With Quote
6x6x18' pressure treated lumber josephyap1111 Building & Construction 3 02-03-2012 11:56 PM
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 04:04 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
How do you tell the diff btw Pressure treated and regular hardwood zhbuyi Carpentry 3 06-08-2008 08:11 PM
