Old 12-01-2007, 03:11 PM   #1
Get Peeling Paint off of Concrete Walkway
Tuesday, about 4 pm, I painted the concrete walkway that leads up to a rental that I am about to rent. I didn't water wash/scrub the floor because of the time of the day and I was running out of it. Big mistake. I painted with about 1/4 of a can of paint that was leftover from the same job 2 years prior. It looked perfect when I finished. The next morning and all day long, we had downpouring rain. Sure enough, by the afternoon, the paint was bubbling in places and is now fully peeling. What do I do now?
BarrytheBuilder is offline   Reply With Quote
Old 12-01-2007, 03:23 PM   #2
Home Improvement Guy
ron schenker's Avatar
Try to scrape it all off and then roll on a bonding agent and then use paint that's specifically for concrete. If you are near a real paint store (not big box) they will have all the info and products you need
ron schenker is offline   Reply With Quote
Old 12-02-2007, 08:37 AM   #3
I would think that a thorough pressure-washing would be able to remove all the failing paint. You can then clean and coat with the appropriate materials from a paint store instead of BigBoxCo.
SirWired
sirwired is offline   Reply With Quote
Old 12-02-2007, 08:46 AM   #4
Tired, Cold, and Damp
slickshift's Avatar
It hasn't cured yet
A good powerwashing should do it
slickshift is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
Peeling paint Lisalovespainting Painting 7 02-17-2007 08:52 AM
Peeling Paint lawlor Painting 2 12-30-2006 03:28 PM
