Gardz Vs. High Build Primer Vs. Skim Coat? - Painting - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 09:06 PM   #1
Rewards Points: 14
Gardz vs. high build primer vs. skim coat?
I have a small bathroom that has a lot of imperfections on the wall due to wallpaper removal.
Wondering if I could use gardz or high build primer to smooth out the imperfections or would skim coat be best option?
thanks
pooneej is offline   Reply With Quote
Old 03-16-2013, 09:14 PM   #2
Rewards Points: 12,828
Any form of paint is just going to make the flaws stick out not cover them up.
Take the time to fix it!
And make sure all the old glue is off the wall!!
Old 03-16-2013, 09:16 PM   #3
Rewards Points: 14
ahh beat
Looks like tomorrow will be spent with some joint compound and a trowel. thankfully its not a large area I have to do
thanks!
Old 03-16-2013, 09:41 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
When I strip paper, I get as much paste off the walls as i can , then before any repairs i give it a coat of Gardz to lock down any paste residue. it will not help with filling imperfections, but it will stop the paste from ruining your job. Then if it needs it a skim, do that - which will be easier because of the Gardz, sand smooth- prime with a primer sealer, and paint.
Sounds like a lot- but it is what I do all the time.
Nobody said this painting stuff was easy ( oh ya, HD did- but they lie..)
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
chrisn (03-17-2013), Gymschu (03-17-2013)
Old 03-17-2013, 04:29 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
What he^ said( especially the last sentence)
Sherwin Williams High Build Primer and questions Abs777 Painting 15 09-30-2013 07:17 AM
Skim Coat over Primer cougar01 Painting 25 07-03-2012 01:43 PM
skim coat over wallpaper paste residue bubbler Drywall & Plaster 6 04-17-2012 03:55 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Paint Over Skim Coat? Please Help Canoe Place Painting 2 09-01-2011 05:04 AM
