Gardz Question - Painting - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 12:56 PM   #1
Rewards Points: 45
Gardz Question
Hi
I have a room that I will be painting that previously had wallpaper on it. All the wallpaper and paste has been removed and I'd like to apply Gardz to seal in any residual paste.
I have some imperfections (divots, holes) on the walls that I will need repair with spackle.
My question is - What the order in which to do things?
Do I apply Gradz to the entire wall and then fix the imperfections with spackle - or - do I spackle first and then coat all the walls with Gardz going over the spackle repairs?
Do I need to apply a primer over the spackle repairs in either scenario? I'm worried about the spot repairs flashing through the paint to the point where they are noticeable??
I've had good luck with Zinsser Bulls Eye 123 water based primer and Ben Moore Regal Select paint in the rest of the house. This is the first time I will be using Gardz.
Thanks!
Dan
dschribs is offline   Reply With Quote
Old 07-30-2013, 12:59 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
You could do it either way- but if you spackle after the Gardz, you will need to spot prime the spackle- usually no big deal.
The main think is that the residue gets sealed- check!
and the spackle gets sealed- check!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
DrHicks (07-31-2013)
Old 07-30-2013, 01:11 PM   #3
Rewards Points: 5,974
Can do either way but why do it twice do your repairs first then prime. Of course a lot of times you will see some areas that require attention and you will probably need to do touch-ups after priming either way.
Old 07-30-2013, 05:37 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Can't add to any of that
Old 07-30-2013, 08:13 PM   #5
Too Short? Cut it Again!
Me either.
Old 07-30-2013, 09:44 PM   #6
Rewards Points: 4,780
Spackle first, Gardz next, done.
jeffnc is offline   Reply With Quote
Old 07-31-2013, 12:25 AM   #7
I almost agree with you depending on how deep the repairs.
And I was hoping this thread could just be closed.
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
Brittle popcorn, water stains: Gardz and/or BIN jfklein13 Painting 7 06-01-2012 10:17 AM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
