Old 10-16-2009, 09:14 PM   #1
Garage peeled paint door.
So I scraped off the garage door peeled paint and sand. Should I continue to scrap off more ? What do I do next?
http://www.flickr.com/photos/23636401@N04/4018247944/
I also did a test, it is latex.
For interior paint what are affordable paint out there better than Behr and lowes paint?
I live in CA by the way.
StevenH is offline   Reply With Quote
Old 10-16-2009, 11:09 PM   #2
Matthewt1970's Avatar
Scrape anything that doesn't put up a good fight to stay stuck onto the surface. Anything is better that Behr or Valspar.
Old 10-16-2009, 11:36 PM   #3
100 Year Family Tradition
4ThGeneration's Avatar
Are you wanting to paint your garage door with interior paint because it is an entry door from your garage into your house?
or
Are you actually wanting to paint your exterior garage door with interior paint
or
Are you wanting to know what interior paint is the best because you also want to paint the interior of your home?
Interior paints for interior projects and exterior paints for exterior projects.
With that said. You said you live in CA. Check out Kelly Moore and Frazee Paints
4ThGeneration is offline   Reply With Quote
Old 10-17-2009, 12:35 AM   #4
Do I apply primer directly onto after scraping ,sanding, or what do you guys use to cover those paint peeled holes?
Old 10-17-2009, 04:57 AM   #5
paper hanger and painter
chrisn's Avatar
Primer is a must.
Old 10-17-2009, 07:28 AM   #6
sdsester's Avatar
If you need to be around the Behr or other crap paint and primer price point use the contractor grades of any of the major paint brands from a real paint store and you will be much better off. Benjamin Moore is my favored brand but I also use a lot of Sherwin Williams. Friends in California use Kelly Moore and seem pleased. That brand is not available near me.
sdsester is offline   Reply With Quote
Old 10-17-2009, 10:19 PM   #7
Originally Posted by chrisn View Post
Primer is a must.
What happens if you didn't use primer?
I am using primer just asking.
Old 10-18-2009, 06:25 AM   #8
chrisn's Avatar
The same thing that is happening in the first place. The primer sticks to the substrate, the paint sticks to the primer( good paint and primer)
Old 10-18-2009, 01:11 PM   #9
It looks like i need more than 3 layers of paint to be even with the original peeled layer.
Right now I'm using leftover kilz2 primer and behr, i know its crap didn't want to throw away it. I wont use it again.
Old 10-18-2009, 03:11 PM   #10
When brushing painting the door trim , baseboard, cuts What is the proper way to use the brush? Do I apply the paint with one stroke, back-brush with another stroke?
I understand it takes years of training and practice. Should i find a job as a painter and start there?
Old 10-20-2009, 10:40 PM   #11
Sprayboy-services.com
No, just go rent "Karate Kid" and practice the "paint the fence" moves.
Sprayboy is offline   Reply With Quote
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
how to paint garage door rocketdoctor Painting 5 09-16-2009 05:38 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 12:36 PM
