Garage Floor Epoxy - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 04:08 PM   #16
Rewards Points: 3,418
"Also on my garage floor is the standard concrete lines, I was wondering what could I use to fill in the gap and make the floor look like one big smooth surface instead of the line. Any advice or tips would be great"
Those "concrete lines" your referring to are control joints, and it's not a good idea to fill them in just to make your floor look like one big smooth surface,as you could wind up with a bunch of cracks going in a bunch of difference directions.
Canarywood1 is offline   Reply With Quote
Old 01-23-2013, 04:16 PM   #17
Rewards Points: 4,792
Unlikely - it would just crack along the control joints if it's going to crack.
jeffnc is offline   Reply With Quote
Old 02-08-2013, 12:24 PM   #18
Grants Painting's Avatar
Garage Floor
You guys are all missing the point that some concrete floor coating are rated for hot tire and some are not. Besides if its a garage floor grinding the cement to get up ALL the oil spots is the best way.
Epoxies bond better than most primers. Unless its an epoxy primer.
Last edited by Gary in WA; 02-09-2013 at 05:54 PM. Reason: removed link per forum rules.
Grants Painting is offline   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 10:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
