Garage Floor Coatings? - Painting - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 02:19 PM   #1
Rewards Points: 358
Garage floor coatings?
Hope this is the right section..
I am wanting to paint my garage floor, but before I go buy one of those fancy garage epoxy floor kits I wanted to double check something. My garage floor is not the smooth style concrete, it is a rough type, very lumpy. Think cottage cheese
Would one of these garage coatings just look weird on on a floor that is not smooth, or do these coatings somewhat flatten out the finish?
Thanks!
cbzdel is offline   Reply With Quote
Old 05-12-2010, 08:25 AM   #2
Concrete is what it is. I am doubtful if a epoxy will fill in what you have explained.
mark942 is offline   Reply With Quote
Old 05-12-2010, 08:28 AM   #3
look into modular tiles like kiwi tile
The older I get the better I was
Old 05-12-2010, 08:40 AM   #4
Rewards Points: 249
Our garage is designated 1/2 for the wife's car and storage, and the other half as my workshop and bike storage. I want so bad to put something like kiwi or racedeck down on my half, but at about 200 sq feet, I can't afford to right now Wife needs a new piano (she teaches lessons), I need new truck tires, a new weedeater, fridge...
Durt Ferguson is offline   Reply With Quote
Old 05-12-2010, 03:52 PM   #5
Sprayboy-services.com
The floor coatings would be OK as long as you don't put the paint flakes on there. That is meant to make the floor look like linoleum. A single color would be OK applied with a 3/4" nap roller. That stuff will scratch however so be forewarned.
Sprayboy is offline   Reply With Quote
Old 05-12-2010, 04:31 PM   #6
Rewards Points: 358
I like the color fakes
actually I just called Quikrete and asked for their thoughts and they told me to first purchase their concrete refinishing kit, which is a mix that turns into a liquid that you pour over your slab and it basically refinished it to a smooth surface, he then said I would have to wait 60 days before I can do a floor finish kit.
Old 05-12-2010, 04:39 PM   #7
A lot of work but it's your floor. Just remember that it will scratch and any solvents spilled on it will affect it. I did my laundry room with it.
Old 05-21-2010, 05:46 PM   #8
Rewards Points: 81
The skim coating on the floor is a risky proposition, especially if you don't have experience with it. And the epoxy coatings aren't cheap.
I had a totally broken up and uneven slab -- poured in 1925 here in earthquake country.
There was no moisture barrier, so epoxy wasn't going to stick. Racedeck would have cost me an arm and a leg and I still would have had to smooth out the floor. So the cheapest/best option I found was ceramic tile. I got these from Home Depot for .68/sf (they're sometimes on sale for less).
They've held up great in my 440 square foot garage.
I had never installed tile before. It's a fair amount of work, but I've been really happy with the results.
I'm told that porcelain tiles (about a buck a square foot, on sale) are even harder. But mine have held up to a lot. My garage gets dirty on a regular basis:
And it's not difficult to replace one if it does break. A lot easier to create a seamless repair than with epoxy.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
