Garage Doors Quote HELP!!!! - Painting - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 03:07 PM   #1
hi guys hope you can help
how much would you charge for 1 garage door + frame to be painted
and how much for 30 garage doors and 30 frames plus fascia boards to be painted
doors are metal
frames and fascia boards are wood
thanks for any replys
painter1001 is offline   Reply With Quote
Old 04-27-2011, 03:11 PM   #2
Thumbs up
also in english not $$$ cheers
in GBP if poss i think this is an english site anyways not sure
Old 04-27-2011, 03:24 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
doors are metal
What I would I would charge and what you would charge are probably 2 numbers far apart. Take your hourly rate times it by the amount of time it will take add material, add direct expenses, add indirect expenses, add profit, add markup, add state, local, and federal taxes. Its really not complicated as long as you know your numbers and production rates
housepaintingny is offline   Reply With Quote
Old 04-27-2011, 06:46 PM   #4
Too Short? Cut it Again!
Yup. Asking for quotes is just too arbitrary and with too many variables.
Are these doors and facia hung or could they be painted in some production like fashion? What kind of primer/ paint?
Old 04-27-2011, 08:29 PM   #5
Gymschu's Avatar
Rewards Points: 932
Just not enough info to even fathom a rough guess. How big are the doors? Garage doors can be 16 feet high or 6 feet high. What type of paint will you be using? One coat or two? An average size garage door in the U.S. can be done by an experienced painter in one or two hours depending on size.
Tags
door , garage , metal , paint , painting
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 09:03 PM
Garage Door Repair Tip doortodoor Windows and Doors 0 03-15-2011 08:05 AM
Painting Old Wood Garage Doors DIYnewbie2 Painting 4 05-14-2009 06:11 AM
Swinging Garage Doors Justin08 Carpentry 1 11-16-2008 10:59 AM
