Gap Between Baseboard And Laminate Floor - Painting - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 12:34 PM   #1
Rewards Points: 518
Gap between baseboard and laminate floor
Whenever I paint baseboards, I usually tape up the floor to avoid getting paint on the floor but I find that some paint always builds up in the gap between the floor and the baseboard and creates a jagged look once the tape is removed and you look at the area from a distance. Using a putty knife or razor after usually makes more of a mess trying to clean up the residual paint. I'm pretty good at cutting in on walls but not so good when it comes to the bottom of a baseboard and I don't feel comfortable brushing against the floor without tape. Any suggestions on how to avoid this or how to clean up the mess?
Is it just a matter of having the least amount of paint on the brush and cutting in as close to the floor as possible?
n0c7 is offline   Reply With Quote
Old 12-22-2010, 07:35 AM   #2
You just answered your own question......................
mark942 is offline   Reply With Quote
Old 01-05-2011, 11:08 AM   #3
Rewards Points: 150
you could use a plastic paint edger, cost a couple bucks and found at all home improvement stores, but you have to wipe the paint off each time you move it. I just keep old rags to wipe the paint off with and you get a clean finish without the danger of removing finish from the floor by using painters tape. It really doesn't take that much longer.
guest is offline   Reply With Quote
Old 01-05-2011, 01:31 PM   #4
Gymschu's Avatar
Rewards Points: 244
Guest has a good suggestion. I use a 10 inch drywall knife if I need to.......it is a pain wiping it each time you move it, but it does work.
baseboard- tile and laminate floor same room fredaL Flooring 0 12-10-2010 09:45 PM
What baseboard to use with laminate floors? eradik Flooring 1 11-07-2010 02:33 PM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 11:44 PM
