Fuzzy White Stuff On Walls - Painting - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 07:51 PM   #1
fuzzy white stuff on walls
after painting drylok on my out side wall to keep the water from coming in i now have fuzzy white stuff growing on the inside of my basement wall. Can you tell me what it is and how to get rid of it.
marybur2 is offline   Reply With Quote
Old 11-07-2011, 09:53 PM   #2
Rewards Points: 256
Hey mary
Sounds like your experiencing effervescence. It’s caused by moisture trapped in the wall. You then sealed it in using the Drylok, it couldn’t pass through the Drylok so it came out on the bare side of the wall. It usually happens on chimneys during the winter months. It’s nothing to worry about it’s just irritating. Use a wire brush to remove it and I would suggest a dehumidifier. It will most likely continue until the moisture in the wall finally is drawn out.
Be patient and keep wire brushing until it stops. You might also be sure you have good outside drainage away from your home. Make sure all downspouts channel the water at least 5-6 feet away from the foundation.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 11-07-2011, 10:25 PM   #3
Military Mom of 4
Snav's Avatar
Yep - that's what it is. Aka efflorescence.
if you don't want to wire it off - which would work fine, I think - and be safe. . sometimes people acid it off. But I wouldn't set about to scrubbing anything with muriatic acid if it'll just work itself out naturally - because considering the danger to you it'll continue to efflorescence until it's all leached out regardless.
The leeching is natural process - you can't stop it in it's tracks.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Painting Walls dalcacio2007 Painting 4 06-23-2011 02:08 AM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
White powder on block foundation walls. lscott Building & Construction 2 05-18-2010 09:32 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
fuzzy white stuff growing on my walls???? yummy mummy Remodeling 7 08-20-2007 10:54 PM
