Fungicide Or Microban Paints To Inhibit Exterior Mold? - Painting - DIY Chatroom Home Improvement Forum
Old 12-25-2009, 12:48 PM   #1
Fungicide or microban paints to inhibit exterior mold?
Hello
I have a problem with mold growing under my exterior eaves. Im considering adding a fungicide to a latex acrylic paint (which should protect for about 5 years), using Messmer's anti-mold exterior paint, or using one of the new paints with "Microban" in it. Consumer Reports rated a paint with microban in August 2009, which did well, but not great, in their long-term tests. I suspect I can also add a fungicide to a micrban paint. Any advice on the best option?
Thanks for any insights.
Penelope
pnlop1 is offline   Reply With Quote
Old 12-25-2009, 01:13 PM   #2
Opps...I should have written "Zinssers" (not Messmer's) Mold & Mildew-Proof Exterior Paint.
Penelope
Old 12-25-2009, 01:26 PM   #3
ccarlisle's Avatar
You know it always helps to tell us where you are located, as some problems and many solutions will be clearer if we know the surrounding circumstances to your problem.
Not knowing if you're in a humid climate or not, I can only toss out generalites such as this one: if you have mould on the exterior, say under the eaves, the you must have more of a problem than just the addition of microban will handle. It may solve the cosmetic issue for a while but you.re just avaoiding the problem if you do.
Mould need humidity, low airflow, and food to grow with. What are you providing as a food for moulds? cellulose, paint, stucco? what? If you're outside how come there is so little air movement that provides almost 80% relative humidity that helps moulds grow?
Rather than mess around with the paints. have you tried bleach?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-25-2009, 01:54 PM   #4
Hi
I live in Los Angeles, and the weather is pretty dry, so the exterior mold is a bit of a mystery (Morning dew?). I attach some pictures. Im re-stuccoing the entire outside (with smooth stucco), and have the option of boxing-in the eaves and covering them with stucco, or repainting them--Im afraid that boxing-in the eaves will just hide mold growth inside them. FYI: there is no attic above them. Im trying to figure out the best option and Im open to suggestions. {I also asked about boxing-in eaves within the roofing section--sorry for the redundancy}
Thank you
Penelope
Old 12-25-2009, 06:32 PM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Bleach and water will remove the mold/mildew spores, but there are some natural remedies such as using baking soda or vinegar. I would use simple green paint prep, mold, mildew remover its biodegradable, green, won't harm you, pets, or plants. I would use that in combination with a pressure washer, then scrape the substrate as needed, prime as needed using a quality primer such as SW problock, caulk as needed using a quality acryilic siliconized caulk, followed by a quality 100% acrylic paint. One of the positive properties of a 100% acrylic paint is that it has mold/mildew inhibiteds in it already. I would use SW Superpaint. Nothing for nothing but consumer reports does not test a lot of products and they don't test a lot of SW products. I would use SW exterior Superpaint over any product that Consumer Reports rates as being good.
housepaintingny is offline   Reply With Quote
Old 12-26-2009, 10:19 AM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I deal with Davis Paint quite a bit. They are a small regional Virginia company who also happen to be the Microban distributor for the area. Their Microban products have been top notch for interior application. They have yet to make an exterior version, claiming that it adds quite a bit to the cost of the product and doesn't really work very well at all in comparison to interior application. It'll keep the spores from multiplying and spreading but on the exterior of a house spores just land on it all the time so you don't really see that much difference. If you have conditions that allow those spores to take hold to begin with, the Microban is just going to keep them from spreading as fast, not keep them away completely. They've had better luck with a Zinc modified product they've had for years.
poppameth is offline   Reply With Quote
Latex over alkyd primer TVC15 Painting 15 08-14-2010 11:42 PM
Oil, Latex, Acrylic... How to Choose? Turkmenbashy Painting 4 01-18-2009 11:30 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Paint sticking at door/jamb Corcoran1 Painting 10 06-20-2008 07:03 AM
