Old 09-11-2010, 12:59 PM   #1
Full Coverage coat of USG SheetRock First Coat Primer
I am applying USG First Coat Primer to my drywall and reading the directions I am wondering what is meant by a "Full Coverage Coat". I am applying by using Brush and Roller method.
In the video on their site for level 5 finish, they mention while explaining spray application method, that it should be 18 to 20 millimeters thick. Is this what I need for brush/roller application also?
bkeech is offline   Reply With Quote
Old 09-11-2010, 05:33 PM   #2
level 5 is a skim coat over what's usually a nice level 4 finish. i haven't used the product you speak of but to perfect a level 4 finish you can roll on watered down compound or possibly use a primer builder. haven't tried the builder and it wouldn't qualify as an actual level 5 but it may give you the same look if the level 4 was finished nicely. plain pva primer is only made to prevent paint soak in, more of a primer sealer so to speak. if you paint new rock expect to use 3 coats. with pva it's 2 coats. since it's often 1/3rd the price of paint it's a no brainer on why it's used.
racebum is offline   Reply With Quote
The Following User Says Thank You to racebum For This Useful Post:
bkeech (09-11-2010)
Primer/paint coverage over old stucco stromer3 Painting 1 05-05-2010 11:47 AM
partial second coat - did I mess up? matt_ Painting 5 09-22-2009 07:17 PM
Can I tint primer with top coat paint? marc61 Painting 6 04-27-2008 10:41 PM
Sheetrock nightmare MRZ Painting 12 05-25-2007 10:23 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
