Frozen Thompson Water Seal.... Still Work? - Painting - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 01:34 PM   #1
Frozen Thompson Water Seal.... still work?
Hey all; I have about 2 gallons left out of 5 from my Thompson Water Seal can, but it has sat out for the winter. Will it still be good to spray on the deck and the fence? Don't really want to spend the money again, but don't want to resurface my deck either!
Cheers!
Ininkus is offline   Reply With Quote
Old 01-04-2009, 02:59 PM   #2
Oldguy
Rehabber's Avatar
Thompsons is nearly worthless before freezing, it can't be much worse now
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-04-2009, 05:12 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Absolutely not
slickshift is offline   Reply With Quote
Old 01-04-2009, 05:13 PM   #4
slickshift's Avatar
Originally Posted by Ininkus
...but don't want to resurface my deck either!
I'd be remiss if not to mention:
Then Don't Use Thompsons
Old 01-04-2009, 05:13 PM   #5
slickshift's Avatar
But yes..freezing will kill it
Old 01-05-2009, 06:23 AM   #6
ccarlisle's Avatar
From what I know about this product, there should not be a problem if you were to use thawed-out frozen product...shake it well first.
That is a technical answer and has nothing to do with perceived value of the product for the particular application you might have in mind.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 01-05-2009, 06:34 AM   #7
Rewards Points: 506
FYI for the original poster. We really aren't kidding. Thompson's really is horrible stuff. Even those folks that aren't very good at testing coatings, Consumer Reports, no longer even bothers to test the stuff after it consistently was at the bottom of their tests (e.g., not worth the can it is packed in) every time they decided to test deck finishes.
SirWired
sirwired is offline   Reply With Quote
Old 01-05-2009, 02:44 PM   #8
wow, no kidding! I knew it was 'consumer grade', but I didn't realize the industry regarded it that way!
Well I'll have to do some shopping around for the stuff I use next year
Why doesn't my hot water last? MWM Plumbing 17 05-12-2015 08:31 PM
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 04:32 PM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
