Old 01-10-2013, 09:26 AM   #1
Front wood door painting
My front exterior door is made of wood. It is time for a new coat of paint, I would like to leave the door on, the door is white, and I want to stay with white. Any tips and what paint should I buy... I.E semi gloss, satin, exterior for a front door. Thanks in advance.
streetneons is offline   Reply With Quote
Old 01-10-2013, 11:05 AM   #2
Gymschu's Avatar
Perhaps a light scuff sanding, wipe down to remove dust and any chalk, let dry and apply a coat of your favorite white paint. I like a nice, hard finish for doors........a semi or high gloss works well. Sherwin Williams makes an all-surface enamel or you could use SuperPaint Semi-Gloss.
Old 01-10-2013, 11:11 AM   #3
Wood doors need to be sealed on all sides.
If not the rails will expand and contract enough to crack the center panels.
Once the paint sets up you need to rap with the side of your hand on the panels to break the paint bond, or once agin it can crack the panels.
The panels need to be able to float.
replacing wet wood under linoleum in front of shower stall Pawl Building & Construction 7 01-01-2012 04:11 AM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Wood Front Door Care jeffro49 General Discussion 2 01-19-2009 03:22 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
